[QGIS-Developer] Rights to merge Pull Request even if CI is red
Nyall Dawson
nyall.dawson at gmail.com
Thu Jun 25 23:28:31 PDT 2026
On Fri, 26 Jun 2026 at 16:18, Tim Sutton <tim at kartoza.com> wrote:
> Hi
> Ill add it to the next PSC agenda - we can get flamed there instead :-P
Thanks Tim, it's much appreciated.
My personal preference would be something like:
- we decouple "core committer" status from git rights. "core committer" is
just a recognition of skills alone. initially it comes with git rights, but
can outlast those.
- git rights expire automatically after a period of inactivity (say 6
months)
- developers who have previously had git rights but lost them due to
inactivity must go through some re-endorsement process to demonstrate that
they are up-to-date with current development policies and the current state
of the codebase
Happy to join in on a psc meeting to discuss if needed!
Nyall
> Regards
> Tim
> On Thu, Jun 25, 2026 at 10:19 PM Nyall Dawson via QGIS-Developer <
> qgis-developer at lists.osgeo.org> wrote:
>> On Thu, 25 Jun 2026 at 21:39, Even Rouault <even.rouault at spatialys.com>
>> wrote:
>> > Hi Nyall,
>> > your answer doesn't really answer my question :-) Is the restriction
>> for every committer or a subset?
>> > Who has rights for changing qgis/qgis github settings? (not necessarily
>> asking for them to be extended, but just so we know). It would be good to
>> communicate when some settings that might affect workflows are adjusted
>> We're definitely overdue for an overhaul on our github rights. Our
>> current policy is LAUGHABLY ridiculous (basically "you get merge rights
>> once, you've got them for life... even if you go off to work for ESRI or
>> disappear off the face of the earth" 🤣).
>> It's not a discussion I feel like leading though. I tried once, and just
>> got flamed for even bringing it up.
>> Nyall
>> > I'd say that we should probably give up for now to auto-merge if it
>> blocks approved pull requests from being merged
>> > Even
>> > Le 25/06/2026 à 13:30, Nyall Dawson a écrit :
>> > On Thu, 25 June 2026, 9:24 pm Even Rouault via QGIS-Developer, <
>> >> Hi Julien,
>> >> I just tried looking at your PR [0] and I also don't seem to have the
>> >> right to force merge it (only "auto-merge" rights that depend on green
>> CI)
>> >> It would be indeed great to have some clarification of who might have
>> >> such rights or not, so we can see if there isn't a bottleneck that must
>> >> be resolved. I'm not sure why we would want such rights to be
>> restricted
>> >> to a subset of people with "regular" merge rights rather than the whole
>> >> group.
>> > An alternative would be to remove the merge rules which require tests
>> to pass -- that'd avoid expanding rights while still allowing the blockage
>> to be removed.
>> > (Downside is that doing this breaks the ability to "auto merge")
>> > Nyall
>> >> Even
>> >> Le 25/06/2026 à 12:24, Julien Cabieces via QGIS-Developer a écrit :
>> >> > Hi devs,
>> >> > I cannot merge PR #66483 [0] because there is at least one unrelated
>> >> > test failure every time the CI is launched (I restarted it 7 times),
>> although the PR was approved
>> >> > 6 days ago.
>> >> > I have already tackled the issue of the test_gui_fileuploader [1]
>> which was
>> >> > failing very often recently because of badssl.com being unstable
>> but there
>> >> > are now other issues.
>> >> > A few months ago, I had the rights to merge a PR even if tests were
>> >> > failing, but I don't have them anymore and I cannot contribute
>> anymore
>> >> > on #66483 related issues (I have more fix commits based on this PR).
>> >> > It seems to me that other code committers still have these rights as
>> I see
>> >> > PRs with a red CI still being merged.
>> >> > May I have these rights too so I can continue to contribute normally?
>> >> > Shall every core committer have these rights ?
>> >> > Kind regards,
>> >> > Julien
>> >> > [0] https://github.com/qgis/QGIS/pull/66483
>> >> > [1] https://github.com/qgis/QGIS/pull/66543
>> >> http://www.spatialys.com
>> >> My software is free, but my time generally not.
>> >> LLMs contribute to global warming and brain rot
>> >> _______________________________________________
>> >> QGIS-Developer mailing list
>> >> QGIS-Developer at lists.osgeo.org
>> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton
> *Kartoza Cofounder*Tim is a member of the QGIS Project Steering Committee
> *T *: +27(0) 87 809 2702 *E *: tim at kartoza.com *W* :
> kartoza.com
> *This email and any attachments are confidential and intended solely for
> the use of the individual or entity to whom they are addressed. If you *
> *have received this email in error, please notify the sender immediately
> and delete it from your system. Unauthorised use, disclosure, or copying*
> *of the contents is prohibited.*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260626/89d83da0/attachment.htm>
