[QGIS-Developer] Rights to merge Pull Request even if CI is red
Tim Sutton tim at kartoza.com
Thu Jun 25 23:18:05 PDT 2026
Hi
Ill add it to the next PSC agenda - we can get flamed there instead :-P
Regards
Tim
On Thu, Jun 25, 2026 at 10:19 PM Nyall Dawson via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> On Thu, 25 Jun 2026 at 21:39, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Hi Nyall,
> > your answer doesn't really answer my question :-) Is the restriction for
> every committer or a subset?
> > Who has rights for changing qgis/qgis github settings? (not necessarily
> asking for them to be extended, but just so we know). It would be good to
> communicate when some settings that might affect workflows are adjusted
> We're definitely overdue for an overhaul on our github rights. Our current
> policy is LAUGHABLY ridiculous (basically "you get merge rights once,
> you've got them for life... even if you go off to work for ESRI or
> disappear off the face of the earth" 🤣).
> It's not a discussion I feel like leading though. I tried once, and just
> got flamed for even bringing it up.
> Nyall
> > I'd say that we should probably give up for now to auto-merge if it
> blocks approved pull requests from being merged
> > Even
> > Le 25/06/2026 à 13:30, Nyall Dawson a écrit :
> > On Thu, 25 June 2026, 9:24 pm Even Rouault via QGIS-Developer, <
> >> Hi Julien,
> >> I just tried looking at your PR [0] and I also don't seem to have the
> >> right to force merge it (only "auto-merge" rights that depend on green
> CI)
> >> It would be indeed great to have some clarification of who might have
> >> such rights or not, so we can see if there isn't a bottleneck that must
> >> be resolved. I'm not sure why we would want such rights to be restricted
> >> to a subset of people with "regular" merge rights rather than the whole
> >> group.
> > An alternative would be to remove the merge rules which require tests to
> pass -- that'd avoid expanding rights while still allowing the blockage to
> be removed.
> > (Downside is that doing this breaks the ability to "auto merge")
> > Nyall
> >> Even
> >> Le 25/06/2026 à 12:24, Julien Cabieces via QGIS-Developer a écrit :
> >> > Hi devs,
> >> > I cannot merge PR #66483 [0] because there is at least one unrelated
> >> > test failure every time the CI is launched (I restarted it 7 times),
> although the PR was approved
> >> > 6 days ago.
> >> > I have already tackled the issue of the test_gui_fileuploader [1]
> which was
> >> > failing very often recently because of badssl.com being unstable but
> there
> >> > are now other issues.
> >> > A few months ago, I had the rights to merge a PR even if tests were
> >> > failing, but I don't have them anymore and I cannot contribute anymore
> >> > on #66483 related issues (I have more fix commits based on this PR).
> >> > It seems to me that other code committers still have these rights as
> I see
> >> > PRs with a red CI still being merged.
> >> > May I have these rights too so I can continue to contribute normally?
> >> > Shall every core committer have these rights ?
> >> > Kind regards,
> >> > Julien
> >> > [0] https://github.com/qgis/QGIS/pull/66483
> >> > [1] https://github.com/qgis/QGIS/pull/66543
> >> http://www.spatialys.com
> >> My software is free, but my time generally not.
> >> LLMs contribute to global warming and brain rot
> >> _______________________________________________
> >> QGIS-Developer mailing list
> >> QGIS-Developer at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
*Kartoza Cofounder*Tim is a member of the QGIS Project Steering Committee
*T *: +27(0) 87 809 2702          *E *: tim at kartoza.com          *W* :
kartoza.com
*This email and any attachments are confidential and intended solely for
the use of the individual or entity to whom they are addressed. If you *
*have received this email in error, please notify the sender immediately
and delete it from your system. Unauthorised use, disclosure, or copying*
*of the contents is prohibited.*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260626/66d33cbb/attachment-0001.htm>
More information about the QGIS-Developer mailing list
