[QGIS-Developer] Rights to merge Pull Request even if CI is red
Nyall Dawson nyall.dawson at gmail.com
Thu Jun 25 14:19:30 PDT 2026
On Thu, 25 Jun 2026 at 21:39, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi Nyall,
> your answer doesn't really answer my question :-) Is the restriction for
every committer or a subset?
> Who has rights for changing qgis/qgis github settings? (not necessarily
asking for them to be extended, but just so we know). It would be good to
communicate when some settings that might affect workflows are adjusted
We're definitely overdue for an overhaul on our github rights. Our current
policy is LAUGHABLY ridiculous (basically "you get merge rights once,
you've got them for life... even if you go off to work for ESRI or
disappear off the face of the earth" 🤣).
It's not a discussion I feel like leading though. I tried once, and just
got flamed for even bringing it up.
Nyall
> I'd say that we should probably give up for now to auto-merge if it
blocks approved pull requests from being merged
> Even
> Le 25/06/2026 à 13:30, Nyall Dawson a écrit :
> On Thu, 25 June 2026, 9:24 pm Even Rouault via QGIS-Developer, <
qgis-developer at lists.osgeo.org> wrote:
>> Hi Julien,
>> I just tried looking at your PR [0] and I also don't seem to have the
>> right to force merge it (only "auto-merge" rights that depend on green
CI)
>> It would be indeed great to have some clarification of who might have
>> such rights or not, so we can see if there isn't a bottleneck that must
>> be resolved. I'm not sure why we would want such rights to be restricted
>> to a subset of people with "regular" merge rights rather than the whole
>> group.
> An alternative would be to remove the merge rules which require tests to
pass -- that'd avoid expanding rights while still allowing the blockage to
be removed.
> (Downside is that doing this breaks the ability to "auto merge")
> Nyall
>> Even
>> Le 25/06/2026 à 12:24, Julien Cabieces via QGIS-Developer a écrit :
>> > Hi devs,
>> > I cannot merge PR #66483 [0] because there is at least one unrelated
>> > test failure every time the CI is launched (I restarted it 7 times),
although the PR was approved
>> > 6 days ago.
>> > I have already tackled the issue of the test_gui_fileuploader [1]
which was
>> > failing very often recently because of badssl.com being unstable but
there
>> > are now other issues.
>> > A few months ago, I had the rights to merge a PR even if tests were
>> > failing, but I don't have them anymore and I cannot contribute anymore
>> > on #66483 related issues (I have more fix commits based on this PR).
>> > It seems to me that other code committers still have these rights as I
see
>> > PRs with a red CI still being merged.
>> > May I have these rights too so I can continue to contribute normally?
>> > Shall every core committer have these rights ?
>> > Kind regards,
>> > Julien
>> > [0] https://github.com/qgis/QGIS/pull/66483
>> > [1] https://github.com/qgis/QGIS/pull/66543
>> http://www.spatialys.com
>> My software is free, but my time generally not.
>> LLMs contribute to global warming and brain rot
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260626/5d4eff54/attachment.htm>
More information about the QGIS-Developer mailing list
