[QGIS-Developer] Rights to merge Pull Request even if CI is red
Nyall Dawson
nyall.dawson at gmail.com
Thu Jun 25 14:11:21 PDT 2026
On Thu, 25 Jun 2026 at 22:59, Julien Cabieces
<julien.cabieces at oslandia.com> wrote:
> I would also be in favor on given up auto-merge to avoid blocking
> approved pull requests with unrelated test failures.
Ok, it's done -- all build/test rules are now disabled.
Nyall
> At least, until we manage to strengthen our CI. I don't mind to ping you
> or anyone else once in a while but I don't want to have to do it every
> time. And at the moment the CI is very often broken.
> Regards,
> Julien
> > Hi Nyall,
> > your answer doesn't really answer my question :-) Is the restriction for every committer or a subset?
> > Who has rights for changing qgis/qgis github settings? (not necessarily asking for them to be extended, but just so we know). It would be good
> > to communicate when some settings that might affect workflows are adjusted
> > I'd say that we should probably give up for now to auto-merge if it blocks approved pull requests from being merged
> > Even
> > Le 25/06/2026 à 13:30, Nyall Dawson a écrit :
> > On Thu, 25 June 2026, 9:24 pm Even Rouault via QGIS-Developer, <qgis-developer at lists.osgeo.org> wrote:
> > Hi Julien,
> > I just tried looking at your PR [0] and I also don't seem to have the
> > right to force merge it (only "auto-merge" rights that depend on green CI)
> > It would be indeed great to have some clarification of who might have
> > such rights or not, so we can see if there isn't a bottleneck that must
> > be resolved. I'm not sure why we would want such rights to be restricted
> > to a subset of people with "regular" merge rights rather than the whole
> > group.
> > An alternative would be to remove the merge rules which require tests to pass -- that'd avoid expanding rights while still allowing the
> > blockage to be removed.
> > (Downside is that doing this breaks the ability to "auto merge")
> > Nyall
> > Even
> > Le 25/06/2026 à 12:24, Julien Cabieces via QGIS-Developer a écrit :
> > > Hi devs,
> > > I cannot merge PR #66483 [0] because there is at least one unrelated
> > > test failure every time the CI is launched (I restarted it 7 times), although the PR was approved
> > > 6 days ago.
> > > I have already tackled the issue of the test_gui_fileuploader [1] which was
> > > failing very often recently because of badssl.com being unstable but there
> > > are now other issues.
> > > A few months ago, I had the rights to merge a PR even if tests were
> > > failing, but I don't have them anymore and I cannot contribute anymore
> > > on #66483 related issues (I have more fix commits based on this PR).
> > > It seems to me that other code committers still have these rights as I see
> > > PRs with a red CI still being merged.
> > > May I have these rights too so I can continue to contribute normally?
> > > Shall every core committer have these rights ?
> > > Kind regards,
> > > Julien
> > > [0] https://github.com/qgis/QGIS/pull/66483
> > > [1] https://github.com/qgis/QGIS/pull/66543
> > http://www.spatialys.com
> > My software is free, but my time generally not.
> > LLMs contribute to global warming and brain rot
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Julien Cabieces
> Senior Developer at Oslandia
