[QGIS-Developer] Reducing the size of our download packages
Alexander Bruy alexander.bruy at gmail.com
Tue Mar 24 01:33:16 PDT 2026
If I'm not wrong, our standalone installer is based on the OSGeo4W and
installs the latter. So users can easily
use the OSGeo4W installer to download any additional dependencies they
want/need.
Another option would be to add an option to the standalone installer to
download grids, similarly to what we had
in the old NSIS installer for Alaska dataset.
пн, 23 бер. 2026 р. о 09:20 Tim Sutton via QGIS-Developer <
qgis-developer at lists.osgeo.org> пише:
> Hi all
> Here in the infrastructure management club for QGIS we have been embarking
> on a plan to slowly divest ourselves of 'big tech'. At the end of last year
> we switched off cloudflare CDN and implemented our own caching servers. At
> that time we were doing around 130TB of throughput (including what was
> being soaked up by Cloudflare). As of last month we did 430TB of throughput
> without the help of Cloudflare.
> We are trying to optimise costs - that bandwidth alone cost us in the
> neighbourhood of 500€ per month. To reduce costs we can approach the
> problem in two way:
> 1. optimise the infrastructure - we (QGIS Devops team) are busy looking
> into ways to do that...
> 2. reduce the download size...
> We are wondering if the datum shift files could be split out from the main
> installer and fetched as an optional extra? Or maybe on demand as you need
> them? We could set up some infrastructure for hosting them, but we would
> need some help on the application side to implement logic to go and grab
> shift files that are not locally cached. Is anyone able to help with this?
> Regards
> Tim
> Tim Sutton
> *Kartoza Cofounder*Tim is a member of the QGIS Project Steering Committee
> *T *: +27(0) 87 809 2702          *E *: tim at kartoza.com          *W* :
> kartoza.com
> *This email and any attachments are confidential and intended solely for
> the use of the individual or entity to whom they are addressed. If you *
> *have received this email in error, please notify the sender immediately
> and delete it from your system. Unauthorised use, disclosure, or copying*
> *of the contents is prohibited.*
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260324/5383fc86/attachment-0001.htm>
More information about the QGIS-Developer mailing list
