[QGIS-Developer] Reducing the size of our download packages
Matthias Kuhn matthias at opengis.ch
Tue Mar 24 02:29:17 PDT 2026
Hi all,
Thanks for raising this discussion, Tim.
There recently was a discussion about that on a github issue.
The new macOS packages didn't ship grid packages out of the box in the
beginning and this was a blocker for some users so I ended up bundling
the data files again with the macOS packages. The full discussion can be
seen here https://github.com/qgis/QGIS/issues/64486
Key takeaways for me: If we want to split this apart, we need to make it
very easy for users to install missing bits, the current process would need
some improvements. If this is shipped as a separate installer package, we
need to make sure it works across all platforms.
Kind regards
Matthias
On Tue, Mar 24, 2026 at 9:33 AM Alexander Bruy via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> If I'm not wrong, our standalone installer is based on the OSGeo4W and
> installs the latter. So users can easily
> use the OSGeo4W installer to download any additional dependencies they
> want/need.
> Another option would be to add an option to the standalone installer to
> download grids, similarly to what we had
> in the old NSIS installer for Alaska dataset.
> пн, 23 бер. 2026 р. о 09:20 Tim Sutton via QGIS-Developer <
> qgis-developer at lists.osgeo.org> пише:
>> Hi all
>> Here in the infrastructure management club for QGIS we have been
>> embarking on a plan to slowly divest ourselves of 'big tech'. At the end of
>> last year we switched off cloudflare CDN and implemented our own caching
>> servers. At that time we were doing around 130TB of throughput (including
>> what was being soaked up by Cloudflare). As of last month we did 430TB of
>> throughput without the help of Cloudflare.
>> We are trying to optimise costs - that bandwidth alone cost us in the
>> neighbourhood of 500€ per month. To reduce costs we can approach the
>> problem in two way:
>> 1. optimise the infrastructure - we (QGIS Devops team) are busy looking
>> into ways to do that...
>> 2. reduce the download size...
>> We are wondering if the datum shift files could be split out from the
>> main installer and fetched as an optional extra? Or maybe on demand as you
>> need them? We could set up some infrastructure for hosting them, but we
>> would need some help on the application side to implement logic to go and
>> grab shift files that are not locally cached. Is anyone able to help with
>> this?
>> Regards
>> Tim
>> Tim Sutton
>> *Kartoza Cofounder*Tim is a member of the QGIS Project Steering Committee
>> *T *: +27(0) 87 809 2702          *E *: tim at kartoza.com          *W* :
>> kartoza.com
>> *This email and any attachments are confidential and intended solely for
>> the use of the individual or entity to whom they are addressed. If you *
>> *have received this email in error, please notify the sender immediately
>> and delete it from your system. Unauthorised use, disclosure, or copying*
>> *of the contents is prohibited.*
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260324/2f4acac1/attachment.htm>
More information about the QGIS-Developer mailing list
