[QGIS-Developer] Reducing the size of our download packages
Régis Haubourg
regis.haubourg at gmail.com
Tue Mar 24 03:01:49 PDT 2026
Maybe we could add a mechanism where proj grid files can be imported to
the user profile, so any user could download grids.
Some caveats to avoid with multi profile management. I'd be in favor of
storing proj grids once per user $APPDATA profile, not in each QGIS profile
Bien cordialement,
Régis Haubourg
On 24/03/2026 10:29, Matthias Kuhn via QGIS-Developer wrote:
> Hi all,
> Thanks for raising this discussion, Tim.
> There recently was a discussion about that on a github issue.
> The new macOS packages didn't ship grid packages out of the box in the
> beginning and this was a blocker for some users so I ended up bundling
> the data files again with the macOS packages. The full discussion can
> be seen here https://github.com/qgis/QGIS/issues/64486
> Key takeaways for me: If we want to split this apart, we need to make
> it very easy for users to install missing bits, the current process
> would need some improvements. If this is shipped as a separate
> installer package, we need to make sure it works across all platforms.
> Kind regards
> Matthias
> On Tue, Mar 24, 2026 at 9:33 AM Alexander Bruy via QGIS-Developer
> <qgis-developer at lists.osgeo.org> wrote:
> If I'm not wrong, our standalone installer is based on the OSGeo4W
> and installs the latter. So users can easily
> use the OSGeo4W installer to download any additional dependencies
> they want/need.
> Another option would be to add an option to the
> standalone installer to download grids, similarly to what we had
> in the old NSIS installer for Alaska dataset.
> пн, 23 бер. 2026 р. о 09:20 Tim Sutton via QGIS-Developer
> <qgis-developer at lists.osgeo.org> пише:
> Hi all
> Here in the infrastructure management club for QGIS we have
> been embarking on a plan to slowly divest ourselves of 'big
> tech'. At the end of last year we switched off cloudflare CDN
> and implemented our own caching servers. At that time we were
> doing around 130TB of throughput (including what was being
> soaked up by Cloudflare). As of last month we did 430TB of
> throughput without the help of Cloudflare.
> We are trying to optimise costs - that bandwidth alone cost us
> in the neighbourhood of 500€ per month. To reduce costs we can
> approach the problem in two way:
> 1. optimise the infrastructure - we (QGIS Devops team) are
> busy looking into ways to do that...
> 2. reduce the download size...
> We are wondering if the datum shift files could be split out
> from the main installer and fetched as an optional extra? Or
> maybe on demand as you need them? We could set up some
> infrastructure for hosting them, but we would need some help
> on the application side to implement logic to go and grab
> shift files that are not locally cached. Is anyone able to
> help with this?
> Regards
> Tim
> Tim Sutton
> *Kartoza Cofounder
> *Tim is a member of the QGIS Project Steering Committee*
> *T *: +27(0) 87 809 2702 *E *:**tim at kartoza.com *W* :
> kartoza.com <http://kartoza.com/>
> /This email and any attachments are confidential and intended
> solely for the use of the individual or entity to whom they
> are addressed. If you /
> /have received this email in error, please notify the sender
> immediately and delete it from your system. Unauthorised use,
> disclosure, or copying/
> /of the contents is prohibited./
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:
> Alexander Bruy
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260324/8df38ba8/attachment.htm>
