[QGIS-Developer] GSoC QGIS Project Proposal
Ismail Sunni
imajimatika at gmail.com
Tue Mar 31 00:23:48 PDT 2026
Hi John and Valentin,
Actually, there was a QGIS GSoC project that developed a QGIS Plugin. It
was the QGIS Resource Sharing Plugin
<https://github.com/QGIS-Contribution/QGIS-ResourceSharing/> (started as
GSoC 2016, and the development is now taken over by the community).
But I agree with Valentin, the idea of the new plugin is perhaps not so
fitting for the GSoC Project for QGIS unless it can improve the QGIS
project/ecosystem in general, like the QGIS Resource Sharing Plugin.
And yes, I also agree that the network analysis might be a good idea. But
not sure if most users prefer to use other tools as the "engine" and use
QGIS as the interface only.
Good luck anyway!
Best regards.
On Mon, Mar 30, 2026 at 3:51 AM Valentin Buira via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi John,
> Unfortunately, I don't think your project quite fit the requirements of
> the QGIS project as GSoC projects are intended to improve the core of
> QGIS instead of adding new plugins. Moreover, I would say the question
> to ask yourself when adding a new feature to the core of QGIS is: "Is
> this feature going to be helpful for at least three different fields ?"
> Since it looks like you are interested in graph theory, an example of
> GSOC would be "Improve network analysis algorithms in QGIS"
> However your master thesis does look interesting (I also did my master
> thesis on accessibility and walkability so I am looking forward to try
> it out if you do a plugin)
> Kind regards,
> Valentin Buira
> PS: Take a look at the existing plugins on accessibility :
> https://plugins.qgis.org/plugins/tags/accessibility/ maybe you can
> build/improve upon pre-existing work
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Ismail Sunni
Software Engineer
ismailsunni.id
ismailsunni.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260331/da50cccf/attachment-0001.htm>
