[QGIS-Developer] QGIS to work without CMD or Powershell possible?
Umar Sarwar
Umar.Sarwar at oldham.gov.uk
Fri Oct 2 07:16:45 PDT 2026
I need some advice please. We are currently trialling to block usage of command prompt and powershell scripts on users' Pcs however this has been causing issues with QGIS as QGIS requires some .bat files running prior to the application opening. Is there a way that we can utilise QGIS and Python within QGIS successfully in a format that doesn't require cmd or powershell?
Best regards,
Umar Sarwar
Systems and Applications Officer
Technology and Digital Services
Oldham Council
Spindles Shopping Centre, George Street, Oldham OL1 1HD
Confidentiality: This email and its contents and any attachments are intended
only for the above named. As the email may contain confidential or legally privileged information,
if you are not, or suspect that you are not, the above named or the person responsible
for delivery of the message to the above named, please delete or destroy the
email and any attachments immediately.
Security and Viruses: This note confirms that this email message has been
swept for the presence of computer viruses. However, we advise that in keeping
with good management practice, the recipient should ensure that the email together
with any attachments are virus free by running a virus scan themselves.
We cannot accept any responsibility for any damage or loss caused by software viruses.
Monitoring: The Council undertakes monitoring of both incoming and outgoing emails.
You should therefore be aware that if you send an email to a person within the Council
it may be subject to any monitoring deemed necessary by the organisation from time to time.
The views of the author may not necessarily reflect those of the Council.
Access as a public body: The Council may be required to disclose this email (or any response to it)
under the Freedom of Information Act, 2000, unless the information in it is covered
by one of the exemptions in the Act.
Data Protection: The council is committed to ensuring that we are transparent about the ways in which
we use personal information and that we have the right controls in place to ensure it is used
responsibly and is kept safe from inappropriate access, theft or misuse. Further information on how
we use personal information and individual's privacy rights can be found at www.oldham.gov.uk/dataprotection
Legal documents: The Council does not accept service of legal documents by email.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20261002/b7229a7f/attachment-0001.htm>
