[QGIS-Developer] Fw: QGIS to work without CMD or Powershell possible?
Umar Sarwar Umar.Sarwar at oldham.gov.uk
Fri Oct 2 07:17:43 PDT 2026
Best regards,
Umar Sarwar
Systems and Applications Officer
Technology and Digital Services
Oldham Council
Spindles Shopping Centre, George Street, Oldham OL1 1HD
From: QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> on behalf of Umar Sarwar via QGIS-Developer <qgis-developer at lists.osgeo.org>
Sent: 02 October 2026 15:16
To: qgis-developer at lists.osgeo.org <qgis-developer at lists.osgeo.org>
Subject: [QGIS-Developer] QGIS to work without CMD or Powershell possible?
I need some advice please. We are currently trialling to block usage of command prompt and powershell scripts on users' Pcs however this has been causing issues with QGIS as QGIS requires some .bat files running prior to the application opening. Is there a way that we can utilise QGIS and Python within QGIS successfully in a format that doesn't require cmd or powershell?
Best regards,
Umar Sarwar
Oldham Council
[https://www.oldham.gov.uk/email-image]<https://www.oldham.gov.uk/emailfooter>
Confidentiality: This email and its contents and any attachments are intended only for the above named. As the email may contain confidential or legally privileged information, if you are not, or suspect that you are not, the above named or the person responsible for delivery of the message to the above named, please delete or destroy the email and any attachments immediately.
Security and Viruses: This note confirms that this email message has been swept for the presence of computer viruses. However, we advise that in keeping with good management practice, the recipient should ensure that the email together with any attachments are virus free by running a virus scan themselves. We cannot accept any responsibility for any damage or loss caused by software viruses.
Monitoring: The Council undertakes monitoring of both incoming and outgoing emails. You should therefore be aware that if you send an email to a person within the Council it may be subject to any monitoring deemed necessary by the organisation from time to time. The views of the author may not necessarily reflect those of the Council.
Access as a public body: The Council may be required to disclose this email (or any response to it) under the Freedom of Information Act, 2000, unless the information in it is covered by one of the exemptions in the Act.
Data Protection: The council is committed to ensuring that we are transparent about the ways in which we use personal information and that we have the right controls in place to ensure it is used responsibly and is kept safe from inappropriate access, theft or misuse. Further information on how we use personal information and individual's privacy rights can be found at www.oldham.gov.uk/dataprotection<http://www.oldham.gov.uk/dataprotection>
Legal documents: The Council does not accept service of legal documents by email.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20261002/cbfadf4d/attachment.htm>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20261002/cbfadf4d/attachment.txt>
More information about the QGIS-Developer mailing list
