[QGIS-Developer] Fw: QGIS to work without CMD or Powershell possible?
regis at qgis.org regis at qgis.org
Sat Oct 3 08:17:26 PDT 2026
Hi Umar,
well as long as Python is authorized on the workstation, the exec_command is also possible from Python.
Power users often run command line tools like gdal to automate tasks.
Be aware that GIS users are often power users, flirting with dev, datascience automation and the best security feature for them is securing the OS environnement and network / datasources privileges.
QGIS without python support is also possible, but is probably not helping anyone, in that case, you should aim toward a web app.
On 02/10/2026 16:17, Umar Sarwar via QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
> Best regards,
> Umar Sarwar
> Systems and Applications Officer
> Technology and Digital Services
> Oldham Council
> Spindles Shopping Centre, George Street, Oldham OL1 1HD
> *From:* QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> on
> behalf of Umar Sarwar via QGIS-Developer <qgis-developer at lists.osgeo.org>
> *Sent:* 02 October 2026 15:16
> *To:* qgis-developer at lists.osgeo.org <qgis-developer at lists.osgeo.org>
> *Subject:* [QGIS-Developer] QGIS to work without CMD or Powershell
> possible?
> Hi,
> I need some advice please. We are currently trialling to block usage of
> command prompt and powershell scripts on users' Pcs however this has
> been causing issues with QGIS as QGIS requires some .bat files running
> prior to the application opening. Is there a way that we can utilise
> QGIS and Python within QGIS successfully in a format that doesn't
> require cmd or powershell?
> Best regards,
> Umar Sarwar
> Oldham Council
> <https://www.oldham.gov.uk/emailfooter>
> *Confidentiality*: This email and its contents and any attachments are
> intended only for the above named. As the email may contain confidential
> or legally privileged information, if you are not, or suspect that you
> are not, the above named or the person responsible for delivery of the
> message to the above named, please delete or destroy the email and any
> attachments immediately.
> *Security and Viruses*: This note confirms that this email message has
> been swept for the presence of computer viruses. However, we advise that
> in keeping with good management practice, the recipient should ensure
> that the email together with any attachments are virus free by running a
> virus scan themselves. We cannot accept any responsibility for any
> damage or loss caused by software viruses.
> *Monitoring*: The Council undertakes monitoring of both incoming and
> outgoing emails. You should therefore be aware that if you send an email
> to a person within the Council it may be subject to any monitoring
> deemed necessary by the organisation from time to time. The views of the
> author may not necessarily reflect those of the Council.
> *Access as a public body*: The Council may be required to disclose this
> email (or any response to it) under the Freedom of Information Act,
> 2000, unless the information in it is covered by one of the exemptions
> in the Act.
> *Data Protection:*The council is committed to ensuring that we are
> transparent about the ways in which we use personal information and that
> we have the right controls in place to ensure it is used responsibly and
> is kept safe from inappropriate access, theft or misuse. Further
> information on how we use personal information and individual's privacy
> rights can be found at www.oldham.gov.uk/dataprotection <http://
> www.oldham.gov.uk/dataprotection>
> *Legal documents*: The Council does not accept service of legal
> documents by email.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
