[QGIS-es] Consulta MySQL
Eduardo Bieñkowski
edukoski en gmail.com
Mar Mayo 10 06:16:54 PDT 2022
Estimad en s,
Estoy teniendo problemas con el plugin MySQL Import
Me crea la conexion pero luego me da error y no carga en la base de datos
la capa.
Ha ocurrido un error mientras se ejecutaba el código de Python:
subprocess.CalledProcessError: Command 'ogr2ogr -f "MySQL"
MYSQL:"datageo,host=localhost,user=edukoski,password=m3rlin,port=3306"
-a_srs "EPSG:4326" -lco engine=MYISAM "primernivel.shp"' returned non-zero
exit status 1.
File "/home/eduardo/.local/share/QGIS/QGIS3/profiles/default/python/plugins/mysqlimport/mysql_import.py",
line 236, in run
subprocess.check_call(command, shell=True)
File "/usr/lib/python3.10/subprocess.py", line 369, in check_call
raise CalledProcessError(retcode, cmd)
non-zero exit status 1.
Versión de Python: 3.10.4 (main, Apr 2 2022, 09:04:19) [GCC 11.2.0]
Versión de QGIS: 3.24.2-Tisler Tisler, 13c1a02865
Ruta de Python:
/home/edu/.local/share/QGIS/QGIS3/profiles/default/python/plugins/cgl_tools
/home/edu/.local/share/QGIS/QGIS3/profiles/default/python/plugins/clusterpoints
- /usr/share/qgis/python
- /home/edu/.local/share/QGIS/QGIS3/profiles/default/python
- /home/edu/.local/share/QGIS/QGIS3/profiles/default/python/plugins
- /usr/share/qgis/python/plugins
- /usr/lib/python310.zip
- /usr/lib/python3.10
- /usr/lib/python3.10/lib-dynload
- /home/eduardo/.local/lib/python3.10/site-packages
- /usr/local/lib/python3.10/dist-packages
- /usr/lib/python3/dist-packages
/home/edu/.local/share/QGIS/QGIS3/profiles/default/python/plugins/kmltools/libs
/home/edu/.local/share/QGIS/QGIS3/profiles/default/python/plugins/mmqgis/forms
/home/edu/.local/share/QGIS/QGIS3/profiles/default/python/plugins/qgis2web
Eduardo
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/qgis-es/attachments/20220510/464e4358/attachment.htm>
Más información sobre la lista de distribución QGIS-es
