[QGIS-it-user] Ubuntu 18.04 e New standalone console tool for running processing algorithms
Totò pigrecoinfinito a gmail.com
Ven 17 Lug 2020 08:47:55 PDT
Andrea Giudiceandrea wrote
> Totò wrote
>> ho commentato tutti i link relativi a qgis e aggiunto solo: deb
>> https://qgis.org/ubuntugis-nightly bionic main
> Come ho scritto in un precedente messaggio, la guida per l'installazione
> "semplice" su Ubuntu riporta di usare il repository
> sudo add-apt-repository "deb     https://qgis.org/ubuntu `lsb_release -c
> -s`
> main"
Usando il repository https://qgis.org/ubuntu, ottengo:
pigreco a lenovo:~$ sudo apt-get install qgis qgis-plugin-grass
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 qgis : Depends: libqgis-3d3.14.0 but it is not going to be installed
        Depends: libqgis-analysis3.14.0 but it is not going to be installed
        Depends: libqgis-app3.14.0 but it is not going to be installed
        Depends: libqgis-core3.14.0 but it is not going to be installed
        Depends: libqgis-gui3.14.0 but it is not going to be installed
        Depends: python3-qgis (= 1:3.14.0+28bionic) but
1:3.15.0+git20200708+a49cb7c9f3+28bionic-ubuntugis is to be installed
        Depends: qgis-providers (= 1:3.14.0+28bionic) but
 qgis-plugin-grass : Depends: qgis-provider-grass (= 1:3.14.0+28bionic) but
                     Depends: grass740
                     Depends: libgdal20 (>= 1.8.0) but it is not going to be
installed
installed
installed
installed
                     Depends: libqgisgrass7-3.14.0 but it is not going to be
installed
E: Unable to correct problems, you have held broken packages.
ormai ho sporcato il mio Ubuntu e non credo funzionerà più nulla.
grazie per il tuo tempo.
saluti
https://pigrecoinfinito.wordpress.com/
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Italian-User-f5250612.html
Maggiori informazioni sulla lista QGIS-it-user
