[QGIS-it-user] Integrare SAGA 7.x in processing
Paolo Cavallini cavallini a faunalia.it
Mer 25 Nov 2020 22:58:51 PST
Concordo in buona parte, ma è un peccato perdere tutta questa conoscenza, e dover rifare daccapo.
On 25 November 2020 23:11:19 CET, Stefano Campus <skampus a gmail.com> wrote:
>https://github.com/qgis/QGIS/issues/40260#issuecomment-733932354
>Riporto quanto consigliato da Nyall Dawson a proposito della scelta dei
>moduli in qgis.
>"Whenever I'm teaching qgis I always recommend that users pick
>algorithms
>in this order:
>Qgis native provider: it's the most actively maintained and will work
>with
>ALL layer sources supported by qgis, also has nice functionality like
>saving results directly into existing geopackages, postgres database,
>etc,
>and the ability to "data define" parameters values so that they vary
>feature by feature. Also very fast, and no loss of attributes/quality
>caused by conversion to intermediate formats.
>Gdal: a fantastic choice for any raster operations. Algorithms are
>super
>robust and extremely well tested, and heavily optimised for speed.
>Grass: algorithms are extremely robust and mature, but very difficult
>to
>learn and suffer from a confusing mash of options. You definitely need
>to
>read the manual before using a tool. Also can be quite slow due to
>forced
>conversion the grass data types, which can also cause loss/modification
>of
>attribute information. But on the plus side, an absolute ton of
>functionality which isn't available elsewhere.
>Saga. Use as an absolute last resort. Don't touch the vector algorithms
>as
>all have better alternatives in the other providers. Badly tested,
>frequently breaks, and unfortunately also often outputs incorrect
>results.
>Use only when there's no other alternative, and make sure you perform
>your
>own qa on the results to verify that the tool is indeed working as
>advertised.
>That's my 2c at least, but it's based on my years of experience in
>using
>and maintaining (and developing) these tools."
>Il mar 24 nov 2020, 22:57 Stefano Campus <skampus a gmail.com> ha
>scritto:
>> ciao a tutti,
>> come ben sapete data la pessima abitudine degli sviluppatori di SAGA
>di
>> cambiare senza preavviso, al momento la versione standard di SAGA
>> supportata
>> in Processing è la versione ltr 2.3.
>> Tuttavia nel corso degli ultimi mesi ci sono vari tentativi di
>integrare in
>> processing anche le ultime versioni di saga 7.x.
>> attraverso un plugin di alexander bruy, non più presente nel suo
>repository
>> [1] (c'è comunque il plugin per utilizzare in Processing gli
>altrettanto
>> validi moduli di Whitebox GIS) ed ora un plugin di northroad sul repo
>> ufficiale (Processing Saga NextGen Provider), è possibile, appunto,
>> utilizzare le ultime versioni di SAGA.
>> oggi invece scaricando la versione GUI di SAGA per windows nel repo
>di
>> Sourceforge [2] ho scoperto che pare che direttamente si possa
>utilizzare
>> SAGA in Processing senza plugin terzi.
>> purtroppo, come spesso succede per la documentazione di SAGA non ho
>mica
>> capito quale sia la procedura sinteticamente illustrata nel
>readme.txt.
>> chiedo dunque a qualcuno se può cortesemente dare un'occhiata al
>contenuto
>> del file saga4qgis.zip contenuto nel pacchetto [2] e mi può dare una
>> propria
>> interpretazione della procedura.
>> grazie mille
>> s.
>> [1] https://plugins.bruy.me/plugins/plugins.xml
>> [2]
>https://sourceforge.net/projects/saga-gis/files/SAGA%20-%207/SAGA%20-%207.8.1/saga-7.8.1_x64.zip/download
>> Sent from:
>> http://osgeo-org.1560.x6.nabble.com/QGIS-Italian-User-f5250612.html
>> QGIS-it-user mailing list
>> QGIS-it-user a lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-it-user
Sorry for being short
Un allegato HTML è stato rimosso...
URL: <http://lists.osgeo.org/pipermail/qgis-it-user/attachments/20201126/0651b69e/attachment-0001.html>
Maggiori informazioni sulla lista QGIS-it-user
