[QGIS-it-user] Non carica il plugin Processing in QGIS 3.16.12 LTR Hannover
Stefano Campus
skampus a gmail.com
Mer 27 Ott 2021 17:16:56 PDT
Non confermo.
Nel mio PC win 10 ho tutto aggiornato via osgeo4w v. 2 e funziona tutto
correttamente.
LTR, LTR dev, stabile e master.
Nessun problema.
s.
Il mer 27 ott 2021, 16:46 Totò Fiandaca <pigrecoinfinito a gmail.com> ha
scritto:
> Dopo ultimo aggiornamento disponibile per il nuovo repository *OSGeo4W
> Network Installer*, noto che all'avvio di QGIS 3.16.12 ho questo
> messaggio e non carica il plugin Processing:
> Impossibile caricare il plugin 'processing'
> ModuleNotFoundError: No module named
> 'processing.algs.saga.SagaNameDecorator'
> Traceback (most recent call last):
> File "C:\OSGeo4W/apps/qgis-ltr/./python\qgis\utils.py", line 312, in loadPlugin
> __import__(packageName)
> File "C:\OSGeo4W/apps/qgis-ltr/./python\qgis\utils.py", line 793, in _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File "C:\OSGeo4W/apps/qgis-ltr/./python/plugins\processing\__init__.py", line 26, in
> from processing.tools.general import * # NOQA
> File "C:\OSGeo4W/apps/qgis-ltr/./python/plugins\processing\tools\general.py", line 32, in
> from processing.core.Processing import Processing
> File "C:\OSGeo4W/apps/qgis-ltr/./python/plugins\processing\core\Processing.py", line 69, in
> from processing.algs.saga.SagaAlgorithmProvider import SagaAlgorithmProvider # NOQA
> File "C:\OSGeo4W/apps/qgis-ltr/./python/plugins\processing\algs\saga\SagaAlgorithmProvider.py", line 36, in
> from .SagaAlgorithm import SagaAlgorithm
> File "C:\OSGeo4W/apps/qgis-ltr/./python/plugins\processing\algs\saga\SagaAlgorithm.py", line 50, in
> from processing.algs.saga.SagaNameDecorator import decoratedAlgorithmName, decoratedGroupName
> ModuleNotFoundError: No module named 'processing.algs.saga.SagaNameDecorator'
> Versione Python: 3.9.5 (tags/v3.9.5:0a7dcbd, May 3 2021, 17:27:52) [MSC
> v.1928 64 bit (AMD64)]
> Versione di QGIS: 3.16.12-Hannover Hannover, be6cb030
> Percorso Python:
> - C:/OSGeo4W/apps/qgis-ltr/./python
> - C:/Users/pigre/AppData/Roaming/QGIS/QGIS3\profiles\default/python
> C:/Users/pigre/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins
> - C:/OSGeo4W/apps/qgis-ltr/./python/plugins
> - C:\OSGeo4W\bin\python39.zip
> - C:\OSGeo4W\apps\Python39\DLLs
> - C:\OSGeo4W\apps\Python39\lib
> - C:\OSGeo4W\bin
> - C:\OSGeo4W\apps\Python39\lib\site-packages
> - C:\OSGeo4W\apps\Python39\lib\site-packages\win32
> - C:\OSGeo4W\apps\Python39\lib\site-packages\win32\lib
> - C:\OSGeo4W\apps\Python39\lib\site-packages\Pythonwin
> C:\Users\pigre\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\kmltools\libs
> C:\Users\pigre\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\mmqgis/forms
> C:\Users/pigre/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\qgis_resource_sharing
> C:\Users\pigre\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\qgis_resource_sharing
> C:\Users\pigre\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\qgis_resource_sharing\ext_libs
> oltre alla 3.16.12 ho installati anche la 3.22.0 e la master che
> funzionano bene;
> dalle novità introdotte nella 3.22 ho letto che 'Move non-native
> processing providers into independent plugins
> <https://changelog.qgis.org/en/qgis/version/3.22/#move-non-native-processing-providers-into-independ>',
> il problema nella 3.16.12 può essere collegato a questa feature? e se sì,
> come ovviare?
> saluti
> *Ing. Salvatore Fiandaca*
> *mobile*.:+39 327.493.8955
> *m*: *pigrecoinfinito a gmail.com <pigrecoinfinito a gmail.com>*
> *C.F*.: FNDSVT71E29Z103G
> *P.IVA*: 06597870820
> *membro QGIS Italia - http://qgis.it/ <http://qgis.it/>*
> *socio GFOSS.it - *http://gfoss.it/
> *blog:*
> * https://pigrecoinfinito.com/ <https://pigrecoinfinito.com/> FB: Co-admin
> - https://www.facebook.com/qgis.it/ <https://www.facebook.com/qgis.it/>**
> <https://www.facebook.com/qgis.it/> *
> *TW: <http://goog_95411464>**https://twitter.com/totofiandaca
> <https://twitter.com/totofiandaca>*
> 43°51'0.54"N 10°34'27.62"E - EPSG:4326
> “Se la conoscenza deve essere aperta a tutti,
> perchè mai limitarne l’accesso?”
> R. Stallman
> Questo documento, allegati inclusi, contiene informazioni di proprietà di
> FIANDACA SALVATORE e deve essere utilizzato esclusivamente dal destinatario
> in relazione alle finalità per le quali è stato ricevuto. E' vietata
> qualsiasi forma di riproduzione o divulgazione senza l'esplicito consenso
> di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega
> di informare tempestivamente il mittente e distruggere la copia in proprio
> possesso.
> QGIS-it-user mailing list
> QGIS-it-user a lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-it-user
Un allegato HTML è stato rimosso...
URL: <http://lists.osgeo.org/pipermail/qgis-it-user/attachments/20211028/a5b16650/attachment.html>
Maggiori informazioni sulla lista
QGIS-it-user
