[Qgis-psc] QGIS Server funding
Andreas Neumann andreas at qgis.org
Wed Jul 5 22:42:34 PDT 2017
Hi René,
Your proposal sounds fine for me. Depending on availability of devs you may
also use more than the 3k - there is just the total limit of the 13k - and
our wish that you (the three involved companies) use it for the best
outcome in the project.
I am also not sure how the holiday seasons effects the QGIS server dev
plans? Can the most important task be completed until feature freeze in mid
August? At least the ones who have an effect on API?
Sorry for coming up that late with the financing proposal - we should have
discussed it earlier. On the other hand, earlier in the year, the financial
situation did not look as good as it does now.
Thanks for your reply and communicating your plans,
Andreas
On 5 July 2017 at 21:24, René-Luc Dhont <rldhont at gmail.com> wrote:
> Hi all,
> Firstly, thanks for approving the funding of QGIS Server refactoring and
> improvements.
> The project "Remove QgsWXSProjectParser" that I have proposed to the Grant
> included this points:
> * Finishing refactoring of GetPrint command
> * Finishing refactoring of GetLegendGraphics command
> * Refactoring of GetFeatureInfo
> * Refactoring of DXF output in the GetMap command
> But some has been already done:
> * Refactoring of DXF output in the GetMap command by 3liz
> * Finishing refactoring of GetLegendGraphics command by Oslandia
> I propose the 3k € reserved for 3Liz will be used to:
> * finish the project "Remove QgsWXSProjectParser"
> Do the PSC and the others QGIS Server devs agree with this proposition ?
> Best regards,
> René-Luc D'Hont
> Le 05/07/2017 à 10:20, Andreas Neumann a écrit :
> Hi all,
> As you may have noticed, we put up a Loomio vote for the funding of QGIS
> server refactoring and improvements. The proposal was approved. See
> https://www.loomio.org/d/ZXyIzGve/proposal-to-fund-
> development-work-on-qgis-server-v3
> The funding is a total of 13k €. 3k is reserved for 3Liz for the project
> "Remove QgsWXSProjectParser".
> The other 10k are available to fulfill the following goals, as stated in
> the Loomio vote:
>    - Finishing refactoring of GetPrint command
>    - Finishing refactoring of GetLegendGraphics command
>    - Refactoring of GetFeatureInfo
>    - Refactoring of DXF output in the GetMap command
>    - Ensure and Increase OGC compliance and performance
> Can we let it up to you as a team (3Liz, Oslandia, Camptopcamp) to
> distribute these 10k € funds according to availability and suitability of
> your devs? Can you please inform us a bit what your plans are - which dev
> will do what so that we are informed?
> We (as PSC and voting members) hope that you will be able to bring QGIS
> server into a usable state, compatible with the previous 2.x version of
> QGIS server.
> Thanks for your feedback/discussion/info.
> Andreas
> Andreas Neumann
> QGIS.ORG board member (treasurer)
Andreas Neumann
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20170706/09d02edc/attachment.html>
More information about the Qgis-psc mailing list
