[Qgis-psc] QGIS Server funding
Paolo Cavallini cavallini at faunalia.it
Thu Jul 6 01:21:13 PDT 2017
Il 6 luglio 2017 08:42:34 EEST, Andreas Neumann <andreas at qgis.org> ha scritto:
>Hi René,
>Your proposal sounds fine for me. Depending on availability of devs you
>may
>also use more than the 3k - there is just the total limit of the 13k -
>and
>our wish that you (the three involved companies) use it for the best
>outcome in the project.
>I am also not sure how the holiday seasons effects the QGIS server dev
>plans? Can the most important task be completed until feature freeze in
>mid
>August? At least the ones who have an effect on API?
>Sorry for coming up that late with the financing proposal - we should
>have
>discussed it earlier. On the other hand, earlier in the year, the
>financial
>situation did not look as good as it does now.
>Thanks for your reply and communicating your plans,
>Andreas
>On 5 July 2017 at 21:24, René-Luc Dhont <rldhont at gmail.com> wrote:
>> Hi all,
>> Firstly, thanks for approving the funding of QGIS Server refactoring
>and
>> improvements.
>> The project "Remove QgsWXSProjectParser" that I have proposed to the
>Grant
>> included this points:
>> * Finishing refactoring of GetPrint command
>> * Finishing refactoring of GetLegendGraphics command
>> * Refactoring of GetFeatureInfo
>> * Refactoring of DXF output in the GetMap command
>> But some has been already done:
>> * Refactoring of DXF output in the GetMap command by 3liz
>> * Finishing refactoring of GetLegendGraphics command by Oslandia
>> I propose the 3k € reserved for 3Liz will be used to:
>> * finish the project "Remove QgsWXSProjectParser"
>> Do the PSC and the others QGIS Server devs agree with this
>proposition ?
>> Best regards,
>> René-Luc D'Hont
>> Le 05/07/2017 à 10:20, Andreas Neumann a écrit :
>> Hi all,
>> As you may have noticed, we put up a Loomio vote for the funding of
>QGIS
>> server refactoring and improvements. The proposal was approved. See
>> https://www.loomio.org/d/ZXyIzGve/proposal-to-fund-
>> development-work-on-qgis-server-v3
>> The funding is a total of 13k €. 3k is reserved for 3Liz for the
>project
>> "Remove QgsWXSProjectParser".
>> The other 10k are available to fulfill the following goals, as stated
>in
>> the Loomio vote:
>>    - Finishing refactoring of GetPrint command
>>    - Finishing refactoring of GetLegendGraphics command
>>    - Refactoring of GetFeatureInfo
>>    - Refactoring of DXF output in the GetMap command
>>    - Ensure and Increase OGC compliance and performance
>> Can we let it up to you as a team (3Liz, Oslandia, Camptopcamp) to
>> distribute these 10k € funds according to availability and
>suitability of
>> your devs? Can you please inform us a bit what your plans are - which
>dev
>> will do what so that we are informed?
>> We (as PSC and voting members) hope that you will be able to bring
>QGIS
>> server into a usable state, compatible with the previous 2.x version
>of
>> QGIS server.
>> Thanks for your feedback/discussion/info.
>> Andreas
>> Andreas Neumann
>> QGIS.ORG board member (treasurer)
>Andreas Neumann
Agreed fully.
Thanks.
Sent from mobile. Sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20170706/19376f21/attachment.html>
More information about the Qgis-psc mailing list
