[Qgis-psc] QGIS Server funding
    Régis Haubourg
    regis.haubourg at gmail.com
    Fri Jul  7 01:47:40 PDT 2017
Hi all,
first thanks very much for that sponsoring, this is very much welcome!
Sorry for holding my answer for two days now, I was trying to coordinate
things a bit.
Concerning the developer calendar for vacations, Paul Blottiere here is
available during summer and will be at Nodebo too.
It's true the workload is pretty heavy and that the feature freeze
approaching will increase that again. It's one of our main concern to
coordinate all the new feature asked on all projects to make it in 3.0.
René Luc, if you take the GetPrint task which was the last remaining for
Oslandia, then we are willing to start directly on OGC conformity during
BugFix period.
Among the available funds, I suggest 3liz uses a bit more than 3k for
GetPrint and Server bugfix (there will be for sure some work for that)
At Oslandia, I would ask for 5k for OGC platform consolidation + auditing
all non conformities, then 3K for starting fixing the biggest blockers.
This lets 2k extension for 3liz.
The mid-term goal is to reach OGC certification for WMS service, which
would be a really good signal to the world ;).
How does that  sounds like to you?
@Yves, please raise the hand if you are willing to take some funds on the
speed benchmark platform, this would also be very welcome by dev's and
customers.
Cheers
Régis
2017-07-06 7:42 GMT+02:00 Andreas Neumann <andreas at qgis.org>:
> Hi René,
> Your proposal sounds fine for me. Depending on availability of devs you
> may also use more than the 3k - there is just the total limit of the 13k -
> and our wish that you (the three involved companies) use it for the best
> outcome in the project.
> I am also not sure how the holiday seasons effects the QGIS server dev
> plans? Can the most important task be completed until feature freeze in mid
> August? At least the ones who have an effect on API?
> Sorry for coming up that late with the financing proposal - we should have
> discussed it earlier. On the other hand, earlier in the year, the financial
> situation did not look as good as it does now.
> Thanks for your reply and communicating your plans,
> Andreas
> On 5 July 2017 at 21:24, René-Luc Dhont <rldhont at gmail.com> wrote:
>> Hi all,
>> Firstly, thanks for approving the funding of QGIS Server refactoring and
>> improvements.
>> The project "Remove QgsWXSProjectParser" that I have proposed to the
>> Grant included this points:
>> * Finishing refactoring of GetPrint command
>> * Finishing refactoring of GetLegendGraphics command
>> * Refactoring of GetFeatureInfo
>> * Refactoring of DXF output in the GetMap command
>> But some has been already done:
>> * Refactoring of DXF output in the GetMap command by 3liz
>> * Finishing refactoring of GetLegendGraphics command by Oslandia
>> I propose the 3k € reserved for 3Liz will be used to:
>> * finish the project "Remove QgsWXSProjectParser"
>> Do the PSC and the others QGIS Server devs agree with this proposition ?
>> Best regards,
>> René-Luc D'Hont
>> Le 05/07/2017 à 10:20, Andreas Neumann a écrit :
>> Hi all,
>> As you may have noticed, we put up a Loomio vote for the funding of QGIS
>> server refactoring and improvements. The proposal was approved. See
>> https://www.loomio.org/d/ZXyIzGve/proposal-to-fund-developme
>> nt-work-on-qgis-server-v3
>> The funding is a total of 13k €. 3k is reserved for 3Liz for the project
>> "Remove QgsWXSProjectParser".
>> The other 10k are available to fulfill the following goals, as stated in
>> the Loomio vote:
>>    - Finishing refactoring of GetPrint command
>>    - Finishing refactoring of GetLegendGraphics command
>>    - Refactoring of GetFeatureInfo
>>    - Refactoring of DXF output in the GetMap command
>>    - Ensure and Increase OGC compliance and performance
>> Can we let it up to you as a team (3Liz, Oslandia, Camptopcamp) to
>> distribute these 10k € funds according to availability and suitability of
>> your devs? Can you please inform us a bit what your plans are - which dev
>> will do what so that we are informed?
>> We (as PSC and voting members) hope that you will be able to bring QGIS
>> server into a usable state, compatible with the previous 2.x version of
>> QGIS server.
>> Thanks for your feedback/discussion/info.
>> Andreas
>> Andreas Neumann
>> QGIS.ORG board member (treasurer)
> Andreas Neumann
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20170707/0591869a/attachment.html>
More information about the Qgis-psc
