[Qgis-psc] QGIS Server funding
René-Luc Dhont
rldhont at gmail.com
Wed Jul 5 12:24:07 PDT 2017
Hi all,
Firstly, thanks for approving the funding of QGIS Server refactoring and
improvements.
The project "Remove QgsWXSProjectParser" that I have proposed to the
Grant included this points:
* Finishing refactoring of GetPrint command
* Finishing refactoring of GetLegendGraphics command
* Refactoring of GetFeatureInfo
* Refactoring of DXF output in the GetMap command
But some has been already done:
* Refactoring of DXF output in the GetMap command by 3liz
* Finishing refactoring of GetLegendGraphics command by Oslandia
I propose the 3k € reserved for 3Liz will be used to:
* finish the project "Remove QgsWXSProjectParser"
Do the PSC and the others QGIS Server devs agree with this proposition ?
Best regards,
René-Luc D'Hont
Le 05/07/2017 à 10:20, Andreas Neumann a écrit :
> Hi all,
> As you may have noticed, we put up a Loomio vote for the funding of
> QGIS server refactoring and improvements. The proposal was approved.
> See
> https://www.loomio.org/d/ZXyIzGve/proposal-to-fund-development-work-on-qgis-server-v3
> The funding is a total of 13k €. 3k is reserved for 3Liz for the
> project "Remove QgsWXSProjectParser".
> The other 10k are available to fulfill the following goals, as stated
> in the Loomio vote:
> * Ensure and Increase OGC compliance and performance
> Can we let it up to you as a team (3Liz, Oslandia, Camptopcamp) to
> distribute these 10k € funds according to availability and suitability
> of your devs? Can you please inform us a bit what your plans are -
> which dev will do what so that we are informed?
> We (as PSC and voting members) hope that you will be able to bring
> QGIS server into a usable state, compatible with the previous 2.x
> version of QGIS server.
> Thanks for your feedback/discussion/info.
> Andreas
> Andreas Neumann
> QGIS.ORG <http://QGIS.ORG> board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20170705/f651f335/attachment.html>
More information about the Qgis-psc
