[Qgis-psc] Fwd: QGIS 3.0 bug fixing effort Nov/Dec 2017
Andreas Neumann andreas at qgis.org
Fri Oct 27 06:38:37 PDT 2017
Forwarding this to the PSC list. It rejected my mail (too many recipients).
Hopefully, this time it gets through.
Andreas
---------- Forwarded message ----------
Date: 27 October 2017 at 15:34
Subject: QGIS 3.0 bug fixing effort Nov/Dec 2017
To: Matthias Kuhn <matthias at opengis.ch>, Nyall Dawson <
nyall.dawson at gmail.com>, Even Rouault <even.rouault at spatialys.com>, Martin
Dobias <martin.dobias at lutraconsulting.co.uk>, Paul Blottiere <
paul.blottiere at oslandia.com>, Alessandro Pasotti <apasotti at gmail.com>,
Sandro Santilli <strk at kbt.io>, "Jürgen E." <jef at norbit.de>, Alexander Bruy <
alexander.bruy at gmail.com>, Nathan Woodrow <madmanwoo at gmail.com>, Giovanni
Manghi <giovanni.manghi at gmail.com>, QGIS PSC <qgis-psc at lists.osgeo.org>
Dear devs and PSC,
The QGIS feature freeze is very close and we are entering bug fixing mode
soon. You mentioned that you can participate in our paid bug fixing program
( hourly rate of € 100.00 ).
I prepared a spreadsheet of all devs who said that they can contribute at
https://docs.google.com/spreadsheets/d/1Cdh-6eAmVCdiZIQGMhu_
Aqgg09tpxsC40BGXQJtYc54/edit#gid=1150018689 (sheet labeled with 3.0) with a
column listing where your expertise in the code base is. Note that this
column was filled in by myself any may be wrong. Please feel free to
change/correct this column for your entry. This column should help you devs
to coordinate and Giovanni when managing the bug queue. Also, the available
days is not binding if you do less - if you want to do more days than
indicated, please first ask me if we have enough funds.
Giovanni, are you again available for managing the queue?
Nathan: I haven't aske you how many days you would be available and in what
areas in the code base you would work. Please fill in your entry!
Did I miss someone who wanted to contribute?
I have prepared another spreadsheet where you please fill in the issues you
fixed: https://docs.google.com/spreadsheets/d/1F6v4g8Ayb3wIt73rxFKD8h4B95MaT
wt-eDit8YvReB0/edit#gid=1356139814 Please reference ticket numbers and
github commits. You can have a look at the sheets of 2.18 and 2.14 how
other devs have filled this in. This list is then pulled in into the
release notes, please do not forget to fill in this list. It will help Tim
and others to create the release notes and help QGIS.ORG in the reporting
how we spent donations and sponsorship money.
I'd like to thank you all in advance for your efforts! This bug fixing and
QA work is very important to QGIS.ORG and to the QGIS users. It is also
very much appreciated by all of us.
Greetings,
Andreas
Andreas Neumann
QGIS.ORG board member (treasurer)
Andreas Neumann
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20171027/8e0a9b0d/attachment.html>
More information about the Qgis-psc mailing list
