[Qgis-psc] Fwd: QGIS 3.0 bug fixing effort Nov/Dec 2017
Tim Sutton tim at kartoza.com
Fri Oct 27 08:12:12 PDT 2017
Hi
Ah thanks for this. I sent mine out too (querying what will happen with the PR’s) before reading yours….
Regards
Tim
> On 27 Oct 2017, at 15:38, Andreas Neumann <andreas at qgis.org> wrote:
> Hi,
> Forwarding this to the PSC list. It rejected my mail (too many recipients).
> Hopefully, this time it gets through.
> Andreas
> ---------- Forwarded message ----------
> From: Andreas Neumann <andreas at qgis.org <mailto:andreas at qgis.org>>
> Date: 27 October 2017 at 15:34
> Subject: QGIS 3.0 bug fixing effort Nov/Dec 2017
> To: Matthias Kuhn <matthias at opengis.ch <mailto:matthias at opengis.ch>>, Nyall Dawson <nyall.dawson at gmail.com <mailto:nyall.dawson at gmail.com>>, Even Rouault <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>>, Martin Dobias <martin.dobias at lutraconsulting.co.uk <mailto:martin.dobias at lutraconsulting.co.uk>>, Paul Blottiere <paul.blottiere at oslandia.com <mailto:paul.blottiere at oslandia.com>>, Alessandro Pasotti <apasotti at gmail.com <mailto:apasotti at gmail.com>>, Sandro Santilli <strk at kbt.io <mailto:strk at kbt.io>>, "Jürgen E." <jef at norbit.de <mailto:jef at norbit.de>>, Alexander Bruy <alexander.bruy at gmail.com <mailto:alexander.bruy at gmail.com>>, Nathan Woodrow <madmanwoo at gmail.com <mailto:madmanwoo at gmail.com>>, Giovanni Manghi <giovanni.manghi at gmail.com <mailto:giovanni.manghi at gmail.com>>, QGIS PSC <qgis-psc at lists.osgeo.org <mailto:qgis-psc at lists.osgeo.org>>
> Dear devs and PSC,
> The QGIS feature freeze is very close and we are entering bug fixing mode soon. You mentioned that you can participate in our paid bug fixing program ( hourly rate of € 100.00 ).
> I prepared a spreadsheet of all devs who said that they can contribute at https://docs.google.com/spreadsheets/d/1Cdh-6eAmVCdiZIQGMhu_Aqgg09tpxsC40BGXQJtYc54/edit#gid=1150018689 <https://docs.google.com/spreadsheets/d/1Cdh-6eAmVCdiZIQGMhu_Aqgg09tpxsC40BGXQJtYc54/edit#gid=1150018689> (sheet labeled with 3.0) with a column listing where your expertise in the code base is. Note that this column was filled in by myself any may be wrong. Please feel free to change/correct this column for your entry. This column should help you devs to coordinate and Giovanni when managing the bug queue. Also, the available days is not binding if you do less - if you want to do more days than indicated, please first ask me if we have enough funds.
> Giovanni, are you again available for managing the queue?
> Nathan: I haven't aske you how many days you would be available and in what areas in the code base you would work. Please fill in your entry!
> Did I miss someone who wanted to contribute?
> I have prepared another spreadsheet where you please fill in the issues you fixed: https://docs.google.com/spreadsheets/d/1F6v4g8Ayb3wIt73rxFKD8h4B95MaTwt-eDit8YvReB0/edit#gid=1356139814 <https://docs.google.com/spreadsheets/d/1F6v4g8Ayb3wIt73rxFKD8h4B95MaTwt-eDit8YvReB0/edit#gid=1356139814> Please reference ticket numbers and github commits. You can have a look at the sheets of 2.18 and 2.14 how other devs have filled this in. This list is then pulled in into the release notes, please do not forget to fill in this list. It will help Tim and others to create the release notes and help QGIS.ORG <http://qgis.org/> in the reporting how we spent donations and sponsorship money.
> I'd like to thank you all in advance for your efforts! This bug fixing and QA work is very important to QGIS.ORG <http://qgis.org/> and to the QGIS users. It is also very much appreciated by all of us.
> Greetings,
> Andreas
> Andreas Neumann
> QGIS.ORG <http://qgis.org/> board member (treasurer)
> Andreas Neumann
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
Tim Sutton
Co-founder: Kartoza
Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20171027/9af0ed0b/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20171027/9af0ed0b/attachment.jpg>
More information about the Qgis-psc mailing list
