[Qgis-psc] Fwd: QGIS 3.0 bug fixing effort Nov/Dec 2017
Luigi Pirelli luipir at gmail.com
Fri Oct 27 09:11:35 PDT 2017
no bugfix effort for 2.18?
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
On 27 October 2017 at 15:38, Andreas Neumann <andreas at qgis.org> wrote:
> Hi,
> Forwarding this to the PSC list. It rejected my mail (too many recipients).
> Hopefully, this time it gets through.
> Andreas
> ---------- Forwarded message ----------
> From: Andreas Neumann <andreas at qgis.org>
> Date: 27 October 2017 at 15:34
> Subject: QGIS 3.0 bug fixing effort Nov/Dec 2017
> To: Matthias Kuhn <matthias at opengis.ch>, Nyall Dawson
> <nyall.dawson at gmail.com>, Even Rouault <even.rouault at spatialys.com>, Martin
> Dobias <martin.dobias at lutraconsulting.co.uk>, Paul Blottiere
> <paul.blottiere at oslandia.com>, Alessandro Pasotti <apasotti at gmail.com>,
> Sandro Santilli <strk at kbt.io>, "Jürgen E." <jef at norbit.de>, Alexander Bruy
> <alexander.bruy at gmail.com>, Nathan Woodrow <madmanwoo at gmail.com>, Giovanni
> Manghi <giovanni.manghi at gmail.com>, QGIS PSC <qgis-psc at lists.osgeo.org>
> Dear devs and PSC,
> The QGIS feature freeze is very close and we are entering bug fixing mode
> soon. You mentioned that you can participate in our paid bug fixing program
> ( hourly rate of € 100.00 ).
> I prepared a spreadsheet of all devs who said that they can contribute at
> https://docs.google.com/spreadsheets/d/1Cdh-6eAmVCdiZIQGMhu_Aqgg09tpxsC40BGXQJtYc54/edit#gid=1150018689
> (sheet labeled with 3.0) with a column listing where your expertise in the
> code base is. Note that this column was filled in by myself any may be
> wrong. Please feel free to change/correct this column for your entry. This
> column should help you devs to coordinate and Giovanni when managing the bug
> queue. Also, the available days is not binding if you do less - if you want
> to do more days than indicated, please first ask me if we have enough funds.
> Giovanni, are you again available for managing the queue?
> Nathan: I haven't aske you how many days you would be available and in what
> areas in the code base you would work. Please fill in your entry!
> Did I miss someone who wanted to contribute?
> I have prepared another spreadsheet where you please fill in the issues you
> fixed:
> https://docs.google.com/spreadsheets/d/1F6v4g8Ayb3wIt73rxFKD8h4B95MaTwt-eDit8YvReB0/edit#gid=1356139814
> Please reference ticket numbers and github commits. You can have a look at
> the sheets of 2.18 and 2.14 how other devs have filled this in. This list is
> then pulled in into the release notes, please do not forget to fill in this
> list. It will help Tim and others to create the release notes and help
> QGIS.ORG in the reporting how we spent donations and sponsorship money.
> I'd like to thank you all in advance for your efforts! This bug fixing and
> QA work is very important to QGIS.ORG and to the QGIS users. It is also very
> much appreciated by all of us.
> Greetings,
> Andreas
> Andreas Neumann
> QGIS.ORG board member (treasurer)
> Andreas Neumann
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
More information about the Qgis-psc mailing list
