[Qgis-psc] Fwd: QGIS 3.0 bug fixing effort Nov/Dec 2017
Andreas Neumann andreas at qgis.org
Sun Oct 29 04:25:58 PDT 2017
Hi Luigi,
There already was a 2.18 bug fixing effort - actually already 2 times - see
https://docs.google.com/spreadsheets/d/1F6v4g8Ayb3wIt73rxFKD8h4B95MaTwt-eDit8YvReB0/edit?usp=sharing
If a bug is fixed and it feasible to backport the fix to an older LTR
version, developers are asked to take this extra effort to backport the
fix. Of course between different major versions this is a bit hard to
realize than between the same major version.
Greetings,
Andreas
On 27 October 2017 at 18:11, Luigi Pirelli <luipir at gmail.com> wrote:
> no bugfix effort for 2.18?
> Luigi Pirelli
> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> * https://www.packtpub.com/big-data-and-business-
> intelligence/mastering-qgis-second-edition
> On 27 October 2017 at 15:38, Andreas Neumann <andreas at qgis.org> wrote:
> > Hi,
> > Forwarding this to the PSC list. It rejected my mail (too many
> recipients).
> > Hopefully, this time it gets through.
> > Andreas
> > ---------- Forwarded message ----------
> > From: Andreas Neumann <andreas at qgis.org>
> > Date: 27 October 2017 at 15:34
> > Subject: QGIS 3.0 bug fixing effort Nov/Dec 2017
> > To: Matthias Kuhn <matthias at opengis.ch>, Nyall Dawson
> > <nyall.dawson at gmail.com>, Even Rouault <even.rouault at spatialys.com>,
> Martin
> > Dobias <martin.dobias at lutraconsulting.co.uk>, Paul Blottiere
> > <paul.blottiere at oslandia.com>, Alessandro Pasotti <apasotti at gmail.com>,
> > Sandro Santilli <strk at kbt.io>, "Jürgen E." <jef at norbit.de>, Alexander
> Bruy
> > <alexander.bruy at gmail.com>, Nathan Woodrow <madmanwoo at gmail.com>,
> Giovanni
> > Manghi <giovanni.manghi at gmail.com>, QGIS PSC <qgis-psc at lists.osgeo.org>
> > Dear devs and PSC,
> > The QGIS feature freeze is very close and we are entering bug fixing mode
> > soon. You mentioned that you can participate in our paid bug fixing
> program
> > ( hourly rate of € 100.00 ).
> > I prepared a spreadsheet of all devs who said that they can contribute at
> > https://docs.google.com/spreadsheets/d/1Cdh-6eAmVCdiZIQGMhu_
> Aqgg09tpxsC40BGXQJtYc54/edit#gid=1150018689
> > (sheet labeled with 3.0) with a column listing where your expertise in
> the
> > code base is. Note that this column was filled in by myself any may be
> > wrong. Please feel free to change/correct this column for your entry.
> This
> > column should help you devs to coordinate and Giovanni when managing the
> bug
> > queue. Also, the available days is not binding if you do less - if you
> want
> > to do more days than indicated, please first ask me if we have enough
> funds.
> > Giovanni, are you again available for managing the queue?
> > Nathan: I haven't aske you how many days you would be available and in
> what
> > areas in the code base you would work. Please fill in your entry!
> > Did I miss someone who wanted to contribute?
> > I have prepared another spreadsheet where you please fill in the issues
> you
> > fixed:
> wt-eDit8YvReB0/edit#gid=1356139814
> > Please reference ticket numbers and github commits. You can have a look
> at
> > the sheets of 2.18 and 2.14 how other devs have filled this in. This
> list is
> > then pulled in into the release notes, please do not forget to fill in
> this
> > list. It will help Tim and others to create the release notes and help
> > QGIS.ORG in the reporting how we spent donations and sponsorship money.
> > I'd like to thank you all in advance for your efforts! This bug fixing
> and
> > QA work is very important to QGIS.ORG and to the QGIS users. It is also
> very
> > much appreciated by all of us.
> > Greetings,
> > Andreas
> > Andreas Neumann
> > QGIS.ORG board member (treasurer)
> > Andreas Neumann
> > Qgis-psc mailing list
> > Qgis-psc at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/qgis-psc
Andreas Neumann
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20171029/ee51884a/attachment.html>
More information about the Qgis-psc mailing list
