[Qgis-psc] News feed
Tim Sutton tim at kartoza.com
Thu Oct 31 04:31:25 PDT 2019
Hi All
Lets not get to heated in our discussion. I think the entry is fine for now. As we learn more how to manage our new capabilities, we can refine things and improve it.
On the technical side, yes it should be easy enough to take the IP address of the client, check it against GeoIP and then determine if the article is in the geofence or not. I can ask one of our devs to do this.
Regards
Tim
> On 31 Oct 2019, at 11:04, Andreas Neumann <andreas at qgis.org> wrote:
> Ok ok.
> If you feel so irritated about german language, I am happy to translate this message into english. No problem. But then you will get a third entry, because the two previous once are cached and not replaced ...
> I am just against restricting our new channel that we finally have, too much, just because it might not interest all users. Let's use this stuff, and not put a lot of restrictions on it. This Postgis day advertised is nothing that is against our code of conduct or so.
> Or does it irritate you that Sourcepole is involved in this event? That would be quite narrow-minded ... It is not just Sourcepole, there is also the City of Zurich involved - and it is certainly not declared as a company advertising event. It is about presenting new versions of QGIS, Postgis and OpenLayers.
> Let's be more inclusive than restrictive!
> Andreas
> On Thu, 31 Oct 2019 at 11:47, Paolo Cavallini <cavallini at faunalia.it <mailto:cavallini at faunalia.it>> wrote:
> Hi all,
> Il 31/10/19 11:14, Matthias Kuhn ha scritto:
> > I would feel irritated if some software would show me news in Finnish.
> > But I'll leave that to the PSC.
> nothing wrong with our Finnnish friends, but I believe most users will
> share your feeling.
> Cheers.
> Paolo Cavallini - www.faunalia.eu <http://www.faunalia.eu/>
> QGIS.ORG <http://qgis.org/> Chair:
> http://planet.qgis.org/planet/user/28/tag/qgis%20board/ <http://planet.qgis.org/planet/user/28/tag/qgis%20board/>
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org <mailto:Qgis-psc at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/qgis-psc <https://lists.osgeo.org/mailman/listinfo/qgis-psc>
> Andreas Neumann
> QGIS.ORG <http://qgis.org/> board member (treasurer)
Tim Sutton
tim at qgis.org
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20191031/6ded6af3/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20191031/6ded6af3/attachment.png>
More information about the Qgis-psc mailing list
