[Qgis-psc] Grants 2020 preparation for voting
Matthias Kuhn matthias at opengis.ch
Mon Jul 6 07:08:42 PDT 2020
Hi Anita, all
Congratulations to all the winning proposals, we have some very good
projects confirmed. Also thanks a lot for running the grant proposal
process perfectly smooth.
Also thanks to all the voting members for taking the time to read up on
the proposals and participate in the democratic process.
We have noticed that the settings registry was again not prioritized. We
are unsure, what exactly the reason was. The other proposals were very
high quality indeed. Maybe it was not deemed important enough, maybe the
conclusion was that it would be easy to find external sponsors or maybe
it was not presented or titled "sexy" enough.
Whatever it may have been, we are convinced that it would be very good
for the QGIS codebase, plugin ecosystem and users. It will
  - reduce the risk for wrong usage of settings (recent bug e.g. [1])
  - make it easier for plugin developers to properly use settings
  - add semantics to settings, it opens up the way to generate a UI for
settings (the same way it's already possible to generate UIs for
processing parameters)
To provide this leap forward with respect to settings management,
OPENGIS.ch would like to jump in and sponsor the missing 2.4K € to
implement this proposal.
If you would like to follow up on this, please let me know.
Thank you very much
Matthias
[1]
https://github.com/qgis/QGIS/pull/37520/files#diff-45bc9c8c414931bca4589d3b221f119dL543
On 7/5/20 4:57 PM, Anita Graser wrote:
> The voting period is now over. I've closed the form and counted the
> votes. You find the preliminary results at:
> https://docs.google.com/spreadsheets/d/10MAeENptW-gi8spkmR_jn0Y-_9iYakR7wtV5XdSZZ1o/edit?usp=sharing
> As it stands now, the 8 top-ranked proposals can be funded within the
> 40k grant budget.
> Could I ask you to please cross-check the results before we announce them.
> Regards,
> Anita
> *Gesendet:* Samstag, 20. Juni 2020 um 16:18 Uhr
> *Von:* "Anita Graser" <anitagraser at gmx.at>
> The call for voting has been sent out now. The deadline is on Sunday,
> July 5th 2020.
> Please get in touch if you are a voting member and haven't received
> the invitation.
> Regards,
> Anita
> On 19.06.2020 18:01, Marco Bernasocchi wrote:
>     Thanks a lot Denis and  Anita for the great work!
>     Cheers
>     Marco
>     On 19.06.20 16:34, Andreas Neumann wrote:
>         Hi,
>         I agree - thanks a lot for your work, Denis!
>         It helps to get a good summary and present it a bit better.
>         Andreas
>         On 2020-06-19 16:24, Anita Graser wrote:
>             Thank you Denis!
>             I think this is an excellent overview of the proposals.
>             My goal is to send the call for voting out tomorrow
>             evening if there are no arguments against it.
>             Regards,
>             Anita
>             On 19.06.2020 13:48, Denis Rouzaud wrote:
>                 Hi Anita,
>                 Here is a first draft of a one page summary of the
>                 grants to be voted on.
>                 https://docs.google.com/document/d/1aiolvIpEGhBZ-iLhZl7cbUP1gPQx1-W83ecijpzNi4o/edit?usp=sharing
>                 It's quite tricky to report the discussion without
>                 looking too negative. I hope this is neutral enough. I
>                 am totally open to suggestions, obviously.
>                 Let me know what you think,
>                 Denis
>                 Le lun. 15 juin 2020 à 19:50, Anita Graser
>                 <anitagraser at gmx.at <mailto:anitagraser at gmx.at>> a écrit :
>                     Thank you Denis!
>                     We need the summaries as soon as possible.
>                     According to our timeline, we wanted to publish
>                     the voting results at the end of June (after a two
>                     week voting period):
>                     https://docs.google.com/document/d/1CNmSJxztrHrqLfillDH8v1zWaMzxFUyYSPT3sut55eQ/edit?usp=sharing
>                     If you can manage to write the summaries by Sunday
>                     21st, we can start the voting and have the results
>                     ready around July 6th.
>                     Regards,
>                     Anita
>                         On Mon, 15 Jun 2020, 19:14 Denis Rouzaud,
>                         <denis.rouzaud at gmail.com
>                         <mailto:denis.rouzaud at gmail.com>> wrote:
>                             Hi,
>                             I can give a hand for this. I can compile
>                             the summaries and comments.
>                             When is it due?
>                             Denis
>                             On Mon, 15 Jun 2020, 19:04 Anita Graser,
>                             <mailto:anitagraser at gmx.at>> wrote:
>                                 Hi,
>                                 Do we have any volunteer for compiling
>                                 the proposal and discussion
>                                 summaries?
>                                 If nobody is available to take care of
>                                 this step - we have to decide if
>                                 we feel comfortable to go ahead with
>                                 the voting without the summaries.
>                                 Regards,
>                                 Anita
>                                 On 13.06.2020 21:06, Anita Graser wrote:
>                                 > Hi,
>                                 > Since the QEP discussion period is
>                                 over now, we need to take the next
>                                 > steps:
>                                 > According to our new process
>                                 (discussed in
>                                 https://github.com/qgis/PSC/issues/31),
>                                 > summaries should be prepared that
>                                 can be sent out to voters.
>                                 > @Paolo are you still available to
>                                 take care of this?
>                                 > Regards,
>                                 > Anita
>                                 _______________________________________________
>                                 > Qgis-psc mailing list
>                                 > Qgis-psc at lists.osgeo.org
>                                 <mailto:Qgis-psc at lists.osgeo.org>
>                                 https://lists.osgeo.org/mailman/listinfo/qgis-psc
>             Qgis-psc at lists.osgeo.org <mailto:Qgis-psc at lists.osgeo.org>
>     Marco Bernasocchi
>     QGIS.org Chair
>     http://berna.io
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20200706/87076369/attachment-0001.html>
More information about the Qgis-psc mailing list
