[Qgis-psc] [Qt-for-Python] report of the technical group
Anita Graser
anitagraser at gmx.at
Thu Feb 10 10:05:15 PST 2022
Dear Denis,
Thank you for the report from your meeting. It is good to see the
discussions advancing further.
> * we recommend to use the 5000€ of development budgeted for 2022 for
the next block to bring a broader set of tests in QGIS core running with
PySide (under Qt6) so the group could meet again, reevaluate the
decision and potentially propose a follow up
> * considering the short amount of time dedicated and the work already
done by OPENGIS, it makes sense in terms of efficiency that OPENGIS also
handles this block (other devs might get involved in the potential next
ones)
> Hereby, we recommend the PSC to sponsor a follow-up on the
investigation of using Qt-for-Python for QGIS’ bindings.
+1 from me.
Regards,
Anita
On 02.02.2022 07:45, Denis Rouzaud wrote:
> Dear PSC,
> Following the report of the evaluation of Qt-for-Python for QGIS' Python
> bindings and its conclusion [0], we proposed [1] to create a group of
> meaningful QGIS
> developers to propose some recommendations on what to do next.
> Alessandro, Julien, Matthias, Nyall and I met and the conclusions are
> the following:
> * we recognize Qt for Python as a valuable potential solution for
> QGIS’ bindings
> * but we cannot take a formal final decision at this stage due to the
> remaining technical unknowns
> * the global amount of work required is considerable (50 to 100 days)
> and imprecise
> * we recommend to investigate more, proceed block by block and
> reevaluate at each step if we are still moving in the right direction
> * this procedure should be a grant for the project to avoid wasting
> money (e.g. deciding after 90% of the whole effort to finally stick to
> PyQt) and for the developers (workload estimation)
> with PySide (under Qt6) so the group could meet again, reevaluate the
> also handles this block (other devs might get involved in the
> potential next ones)
> For the technical group,
> Denis
> [0] https://github.com/qgis/QGIS-Enhancement-Proposals/issues/237
> [1] https://lists.osgeo.org/pipermail/qgis-psc/2021-November/009568.html
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
More information about the Qgis-psc
