[Qgis-psc] Qt6 status
Nyall Dawson
nyall.dawson at gmail.com
Wed Sep 3 00:24:35 PDT 2025
On Wed, 3 Sept 2025, 5:03 pm Andreas Neumann, <andreas at qgis.org> wrote:
> HI Nyall,
> Thank you for the status update and your work!
> Question: do you still prefer the skipping of one release and then release
> of QGIS 4.0 in February 2026? Just to be clear on this
IMO, yes -- we should skip.
Nyall
> Thank you for your reply,
> Andreas
> On Wed, 3 Sept 2025 at 00:30, Nyall Dawson via QGIS-PSC <
> qgis-psc at lists.osgeo.org> wrote:
>> On Mon, 25 Aug 2025 at 11:47, Nyall Dawson <nyall.dawson at gmail.com>
>> wrote:
>> > On Sat, 23 Aug 2025 at 19:35, Mathieu Pellerin via QGIS-PSC
>> > <qgis-psc at lists.osgeo.org> wrote:
>> > > With regards to the timeline question raised by Marco in this thread,
>> I'd like to add a +1 to the idea of postponing QGIS 4.0. At the very least,
>> I think we should make a conscious decision about it sooner than later :)
>> > I'm also +1 to deferring QGIS 4.0 for one release cycle. (ie skip
>> > October's release, and release 4.0 in February).
>> > The CI port to Qt 6 is basically ready now (at
>> > https://github.com/qgis/QGIS/pull/62809). However -- there's still a
>> > handful of tests which pass under Qt 5 which are skipped on the Qt 6
>> > builds right now, and this makes me nervous. If we merged #62809 today
>> > and moved exclusively to Qt 6 then we'll lose some test coverage. I'd
>> > prefer to hold off merging #62809 until we can get these remaining
>> > tests passing on the ubuntu qt6 builds.
>> Status update: we've now moved ALL of testing CI to Qt 6! 🥳 All tests
>> which were passing on qt 5 are now passing on qt 6, and a handful of
>> underlying issues which were breaking these remaining tests have been fixed.
>> Nyall
>> QGIS-PSC mailing list
>> QGIS-PSC at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
> Andreas Neumann
> QGIS.ORG board member (treasurer)
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20250903/2a2d196d/attachment-0001.htm>
More information about the QGIS-PSC
