[Qgis-tr] Strange string
Xan Vieiro gallaecia6 at gmail.com
Sun Feb 16 22:10:05 PST 2014
Hi Alexandre!
This is how I translated to galician:
"As sondaxes multipunto deben dividirse en varias entidades de sondaxe de
punto simple. As xeometrías multipunto non son ben manexadas pola maioría
dos formatos, polo que é conveniente divivi-las entidades de sondaxe
individuais con moitos puntos en moitas entidades de punto simple."
Hope it can help.
Saúdos
2014-02-17 2:58 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
> Hi Alexandre!
> The File (Strings) you are speaking from is mostly taken from the
> description on
> http://gdal.org/ogr/ogr_formats.html
> I that specific case it is from
> http://gdal.org/ogr/drv_s57.html
> I can remember taking it (and at the same moment wondering what
> soundings have to to with vector formats) but as you can see this file
> format seems to be used in some "sonar" systems.
> If you know a way of better describing it you are more than welcome,
> honestly I just took the description from that webpage to just have a
> description available in QGIS (otherwise we would have had no
> description at all for all those options to turn on and off).
> This is all in the vectorformatfilewriter..
> I think it is hard to know every file format and what it does..
> personally I never came in touch with an S57 File ..
> Hope that explanation helps a bit in understanding
> thanks and kind regards
> Werner
> On Mon, Feb 17, 2014 at 5:46 AM, Alexandre Neto <senhor.neto at gmail.com>
> wrote:
> > I'm trying to translate the following string from QObject, but I not
> > understand its meaning, a it seams to have some spelling problems.
> > "Should multipoint soundings be split into many single point sounding
> > features. Multipoint geometries are not well handle by many formats, so
> it
> > can be convenient to split single sounding features with many points into
> > many single point features."
> > How can we make it clearer in the source?
> > Alexandre Neto
> > Qgis-tr mailing list
> > Qgis-tr at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20140217/8f2ac224/attachment.html>
More information about the Qgis-tr mailing list
