[Qgis-tr] Translation Pull Request to the release branch is acceptable?
Werner Macho
werner.macho at gmail.com
Fri Nov 28 02:27:39 PST 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Richard!
I do not expect many changes in strings in the LTS branch but as I
could see right now there are at least some changes (I was surprised
by the 2.6.1 release).
Personally I think we must give translators a chance to bring up the
LTS release as far as they can - even when they start from like 10%.
I am heavily in favor of creating a LTS part (only for the desktop
application) probably call it qgis-application-lts and with the
branching of the LTS release the scripts inside LTS have to be
adjusted to point to that transifex resource.
Master is evolving too fast (even in terms of strings) to keep
everything bound to master.
In that way translators can work on both - bring up the LTS release if
they want to (and that will be more or less string-stable over 1 year)
OR keep up with normal day to day translations on master.
Why do you think it is better to provide only one transifex translation?
I could even keep the LTS translations in my account on transifex to
make it easer to see the difference.
kind regards
Werner
On 11/28/2014 09:32 AM, Richard Duivenvoorde wrote:
> On 28-11-14 08:55, Werner Macho wrote:
>> Hi!
>> There are already a lot of string changes in master .. so for
>> 2.6.1 we can not take the translations from transifex. For now
>> you can switch to the release-2_6 branch, download the qgis_xx.ts
>> file and create a pull request on that branch.
>> I personally expect no string changes when we switch to the LTS
>> branching from 2.8 on - but you are right we should give people
>> the possibility to continue translation on that branch. I will
>> come up with something for that. Until than - please do it the
>> "old" style for 2.6.1 and create pull requests on release-2_6
>> branch.
> Hi Werner,
> my idea: let's not keep different branches in Transifex for QGIS,
> keep it simple there.
> So for now your 'download ts - upload ts' file is a good solution,
> but maybe for next releases we should make Transifex not follow
> master immediately, but let it follow the release branch for ....
> half of the release-development period (? or so ?). Then the next
> half of the period we switch over and translators can dive into the
> testing/dev branch at that moment.
> What about that?
> Regards,
> _______________________________________________ Qgis-tr mailing
> list Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.15 (GNU/Linux)
iEYEARECAAYFAlR4ThsACgkQDAH1YiCxBgnBYACfS1qs722q4L0lxjXRFxZgVlIk
d/0AnRJL1WJIjQZY+sP/XzJIJ7N8swl8
=cujq
-----END PGP SIGNATURE-----
More information about the Qgis-tr
