[Qgis-tr] Outdated helptext in transifex 10801
Werner Macho
werner.macho at gmail.com
Tue Oct 28 14:41:24 PDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi!
It might be (more it is sure) that the contect help is outdated.
There are developments going on in moving from context help to
integrate documentation (which is done in the Documentation Project)
into the main application to either link to online documentation or
provide the documentation within the Desktop application - but we are
quiet not there yet.
Keeping the context help up to date would probably also help in
improving the documentation, so it is always a nice thing in providing
pull requests to the original source to improve documentation and
context help.
So if you have time to write and improve the context help for this
case it would be great to have a pull request.
The other thing of integrating documentation inside Application is
still work in progress and not ready yet.
kind regards
Werner
On 10/28/2014 07:27 PM, Klas Karlsson wrote:
> string 10801: "Vector layer properties" starts with:
> Vector Layer Properties</h3>? This dialog allows you to work with
> vector layer settings and properties. There are _seven_ tabs:
> Unless QGIS 2.6 has changed a lot there should be ten tabs?
> Is the helptext outdated?
> I will still translate the text that is there, but the original
> text may need updating...
> /Klas
> _______________________________________________ Qgis-tr mailing
> list Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.15 (GNU/Linux)
iEYEARECAAYFAlRQDX8ACgkQDAH1YiCxBgnR1wCfVXZhapBzB8YCJ0WtgMgqjCq0
svQAnRgit6IB3M3UktRKAr7lLXoEb8K9
=RIEE
-----END PGP SIGNATURE-----
More information about the Qgis-tr
