[Qgis-tr] ⦠sufix
Ari Jolma ari.jolma at gmail.com
Sat Mar 10 00:34:22 PST 2018
On 10.03.2018 08:57, Ari Jolma wrote:
> Xan,
> The "…" originates from encoding confusion somewhere along the workflow.
What seems to happen - and I guess Jürgen could explain better and
hopefully provide a fix somewhere - is the following. I'm looking at
AddScriptFromFileAction.py source code which is python.
1) the ellipsis character is a three byte UTF8 character in the source
code (e2 80 a6)
2) the string is read by pylupdate5 and put into a ts file as
… (this is in my linux, pylupdate5 version 5.5.1)
3) those three HTML hexadecimal entities are interpreted as three
characters on the browser
If I change the three character junk string with an ellipsis character
in the ts file I download from transifex, the string is correctly
translated in QGIS. Otherwise it is not.
Ari
> It is originally an ellipsis ('...' as one character). You should
> translate it with an ellipsis or with three dots.
> Ari
> On 10.03.2018 08:52, Xan Vieiro wrote:
>> Transifex Webtranslation page for QGIS is onhttps://www.transifex.com/qgis/
>> Hi,
>> Translating via Transifex I've found 3 similar strings:
>> 1034   Delete Script…
>> 1035   Delete Script…
>> 1036   Delete Script
>> I've translated 1035 as "Eliminar Script..." and 1036 as "Eliminar
>> Script", so the question is should I translate 1034 as "Eliminar
>> Scriptâ¦"?
>> Regards,
>> Xan V.
>> QGIS-Translators mailing list
>> Qgis-tr at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20180310/17729162/attachment-0001.html>
More information about the Qgis-tr mailing list
