[QGIS-trac] Re: [Quantum GIS] #1912: [PATCH] area not null for
symbols with value zero
Quantum GIS
qgis at qgis.org
Thu Dec 17 10:40:33 EST 2009
#1912: [PATCH] area not null for symbols with value zero
Reporter: alicebtoklas | Owner:
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.4.0
Component: Symbology | Version: HEAD
Resolution: | Keywords: area symbols
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 0
Changes (by mlennert):
* cc: msieczka, homann (added)
* summary: area not null for symbols with value zero => [PATCH] area not
* must_fix: No => Yes
Comment:
Replying to [ticket:1912 alicebtoklas]:
> using the "area scale field" to change the size of my point symbols, I
get small symbols where the value in this field is zero, instead of no
symbol at all. I think it's a big problem.
Found the culprit: http://trac.osgeo.org/qgis/changeset/9513, which
responds to http://trac.osgeo.org/qgis/ticket/1186 (putting Maciek and
homann in cc, so that they can possibly react as well).
Applying the following patch, solves the problem of this current bug,
while apparently not reopening #1186:
Index: qgsmarkercatalogue.cpp
--- qgsmarkercatalogue.cpp (révision 12502)
+++ qgsmarkercatalogue.cpp (copie de travail)
@@ -118,12 +118,6 @@
// First prepare the paintdevice that the marker will be drawn onto
- // Introduce a minimum size, we don't want it to disappear.
- if ( size < 4 )
- size = 4;
QImage myImage;
int imageSize;
if ( fullName.startsWith( "hard:" ) )
As already mentioned, this is a show-stopper for any proportionate symbol
cartography in QGIS, and so should be solved ASAP.
I'm also a bit skeptical about the second part of #9513:
- if ( name == "circle" )
+ // If radius is 0, draw a circle, so it wont disappear.
+ if ( name == "circle" || r < 1)
Why does r have to be defined as int ? And is this maybe deprecated since
http://trac.osgeo.org/qgis/changeset/8976 ? I don't have the time to delve
any deeper into the source code, but maybe someone can have a look.
But in any case, most of the issue of this bug seems to be solved by above
patch.
Moritz
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1912#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
