[QGIS-trac] [Quantum GIS] #2292: qgis saves .SHP file as .shp
Quantum GIS
qgis at qgis.org
Thu Dec 17 11:00:44 EST 2009
Reporter: Barryrowlingson | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.4.0
Component: Data Provider | Version: HEAD
Keywords: | Platform_version:
Platform: Unix | Must_fix: No
Status_info: 0 |
Load polygonal shapefile FOO.SHP (with FOO.DBF, FOO.SHX etc). Enable
editing. Select two features and use Merge Selected Features. Disable
editing and save changes. Qgis gives you FOO.shp, FOO.shx and FOO.dbf
alongside your original files.
Just moving nodes around doesn't do this, but deleting a feature does, so
I suspect it's whenever the structure changes and the whole shapefile
needs rewriting....
Probably a Unixy case-sensitive file system problem only.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2292>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
