[QGIS-trac] [Quantum GIS] #3290: Ref. IGNF:LAMB93 not shown in
	recently used SRS
    Quantum GIS
    qgis at qgis.org
    Fri Dec  3 10:40:34 EST 2010
#3290: Ref. IGNF:LAMB93 not shown in recently used SRS
   Reporter:  jrm                                        |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.7.0
  Component:  Projection Support                         |            Version:
   Keywords:                                             |   Platform_version:
   Platform:  All                                        |           Must_fix:  Yes
Status_info:  0                                          |
 If you specify the projection LAMB93 from the IGNF register as the
 projection of the project, the CRS that is added to the recently used CRS
 list is the the ESPG projection code 2154.
 Even if these two projections are supposed to be the same, the IGNF code
 has different parameters from the EPSG which impact transformation and
 localization.
 This is causing problems when the user doesn't pay attention to it and
 rely too much on the text "Lambert 93", the IGNF should be present as it
 is and not replaced by the EPSG's one.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3290>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
