[QGIS-trac] [Quantum GIS] #3291: when digitizing,
show vertexes of the layer, you catch from
Quantum GIS
qgis at qgis.org
Fri Dec 3 16:02:13 EST 2010
#3291: when digitizing, show vertexes of the layer, you catch from
Reporter: gespiel | Owner: nobody
Type: enhancement | Status: new
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: Digitising | Version: Trunk
Keywords: | Platform_version: xp sp3
Platform: Windows | Must_fix: No
Status_info: 0 |
a lot of thanks for the popup window to change the catching options since
ver. 1.7.
When digitising objects, you do not see vertexes of the backgroundlayer,
you catch from. In result, vertexes will forget and the digitised objects
are not prefect.
In the window "catchingoptions", it would be goud to have an option field
"show vertexes" of the layer, you catch from.
An example is in the the attached file.
Thanks for a solution.
Gerhard
Ticket URL: <https://trac.osgeo.org/qgis/ticket/3291>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
