[QGIS-trac] Re: [Quantum GIS] #3222: Fast,
easy and beautiful on the fly rule-based rendering of OSM maps
Quantum GIS
qgis at qgis.org
Tue Dec 28 15:38:56 EST 2010
#3222: Fast, easy and beautiful on the fly rule-based rendering of OSM maps
Reporter: mayeulk | Owner: wonder
Type: patch | Status: new
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: Symbology | Version:
Keywords: | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
Comment(by mayeulk):
Thanks for your comments Martin. I am working on modifying the patch
following your suggestion. Still, as a temporary workaround for the
unavailability of symbol levels in rule-based renderer, I'm thinking of
the following temporary fix:
- if symbol levels are disabled, use all matching rules
- if symbol levels are enabled, use only the first matching rule
Currently, symbol levels are disabled even if you check the symbol levels
check box, so the current solution is temporary anyway and this proposed
temporary fix will improve this. What do you think?
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3222#comment:12>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
