[QGIS-trac] Re: [Quantum GIS] #3222: Fast,
easy and beautiful on the fly rule-based rendering of OSM maps
Quantum GIS
qgis at qgis.org
Tue Dec 28 18:09:15 EST 2010
#3222: Fast, easy and beautiful on the fly rule-based rendering of OSM maps
Reporter: mayeulk | Owner: wonder
Type: patch | Status: new
Priority: major: does not work as expected | Milestone: Version 1.7.0
Component: Symbology | Version:
Keywords: | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
Comment(by mayeulk):
I have reversed symbolForFeature() (see patch above). I also put comments
next to 3 lines:
// return mCurrentSymbol; // uncomment this out to disable
UsingSymbolLevels
if( !usingSymbolLevels() ) return mCurrentSymbol;// comment this
out to disable UsingSymbolLevels
r->setUsingSymbolLevels( usingSymbolLevels() ); // comment this out to
Disabling symbollevels will simply draw not map if symbollevel checkbox is
checked.
If those 3 lines are left unchanged, symbol levels work correctly (still,
only the first matching rule provides the symbol). Rendering without
symbol levels work as well.
Anyway, should you apply or not those 3 lines, the result is the same:
rendering works nicely and is stable, but trying to turn on or off symbol
levels generally crashes qgis:
Checking or unchecking the "Enable symbol levels" checkbox, then clicking
"OK" then "Apply" generally crashes qgis.
A workaround is to disable rendering or disable the layer, open the "Layer
Properties" Dialog, open the "Symbol Levels" dialog, switch (on or off)
the "Enable symbol levels" box, press "OK", then press "OK", then re-
enable rendering or re-enable the layer. In this case it seems to be
stable. I have no idea how to change the code to avoid that crash without
this workaround 8-(
Mayeul
Ticket URL: <http://trac.osgeo.org/qgis/ticket/3222#comment:13>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
