[Qgis-us-user] question about linking multiple data sets so they can be turned on/off
Kerrie Bushway kbushway at gmail.com
Sun May 12 10:00:10 PDT 2019
You can select all the layers for 2018 and right-click (working off memory)
and place in a group which you can then label "2018". Then add all your
2016 layers and group it as "2016". That way, you only have to
check/uncheck one box for the "group" and it turns on/off all the layers in
that group.
Hope this helps!
Kerrie
On Sun, May 12, 2019 at 11:28 AM Dan Nichols <dan.nichols at gmail.com> wrote:
> Not sure if I posted anything about this before but still looking for
> answers.
> I'm new to QGIS, obviously.
> I've loaded a shapefile of a us congressional district, which spreads
> across 3 counties
> Next I have added shapefiles of voter precincts in those counties.
> Next I have joined excel files of voter data from 2018 to the 3 individual
> counties/precincts.
> So I have the district and 3 county/precinct/data layers. I've added a
> color ramp
> so far all good, pretty excited at what I accomplished.
> Now I want to add data from 2016
> I understand I could join additional excel files, but then all the data
> from both years would
> be included. What I want is to be able to select/unselect the 2 years,
> ultimately be able to add
> additional data, such as demographics. Need to be able to turn on/off each
> data set.
> I got the impression somewhere I could save/export what I have so far,
> start over? and do the same thing with the other data? but I'm not at all
> clear on exactly how to do that.
> Any help greatly appreciated.
> Thanks,
> Dan
> Qgis-us-user mailing list
> Qgis-us-user at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-us-user
URL: <http://lists.osgeo.org/pipermail/qgis-us-user/attachments/20190512/00789e97/attachment.html>
More information about the Qgis-us-user mailing list
