[Qgis-user] Postgres dependency on mac build
John Abraham jabraham at ucalgary.ca
Sun Apr 20 11:59:23 PDT 2008
Looks like that might have done it, thanks.  -D POSTGRES_CONFIG=/usr/
local/pgsql/bin/pg_config to cmake.
I'm off an running.  Looks like it's not 64bit.  Is it multithreaded?
I have a new Mac Pro.
John
On 20-Apr-08, at 12:21 PM, William Kyngesburye wrote:
> Puzzling why it's not finding Postgres without any options.
> But, the CONFIG option should point to a file (pg_config), not a
> folder. (Same goes for library options, but not for include dir
> options)
> I've noticed that the "Found ..." feedback is not always correct, or
> you just have to read more into what it says.  Like your Postgres
> response: it says "it's a directory", which can mean "it's not
> supposed to be a directory".
> Also, when reconfiguring, make sure to clean first, or it may
> remember the previous configuration.  Cleaning is not thorough in
> cmake, so the easiest way is to build outside the source.  ie:
> in the qgis source dir,
> mkdir build-osx
> cd build-osx
> cmake [your options] ..
> (note the .. instead of . for the source dir option)  Then you can
> just trash the contents on build-osx to clean, before reconfiguring.
> On Apr 20, 2008, at 12:58 PM, John Abraham wrote:
>> Thanks for the hint.  I can't see a difference (svn diff) between
>> the two cmake directories.
>> I tried deleting my build directory, and redoing the cmake command
>> with -D POSTGRES_CONFIG=/usr/local/pgsql/  and it responded
>> -- Found PostgreSQL: sh: /usr/local/pgsql: is a directory/libpq.dylib
>> but then I got the same error (below) when I ran make :(
>> John
>> [ 43%] Building CXX object src/app/CMakeFiles/qgis.dir/qgisapp.o
>> In file included from /Users/jabraham/Development/qgis/src/src/app/
>> qgisapp.cpp:168:
>> /Users/jabraham/Development/qgis/src/src/app/qgsdbsourceselect.h:
>> 27:22: error: libpq-fe.h: No such file or directory
>> 112: error: ‘PGconn’ has not been declared
>> 118: error: ‘PGconn’ has not been declared
>> 141: error: ISO C++ forbids declaration of ‘PGconn’ with no type
>> 141: error: expected ‘;’ before ‘*’ token
>> make[2]: *** [src/app/CMakeFiles/qgis.dir/qgisapp.o] Error 1
>> make[1]: *** [src/app/CMakeFiles/qgis.dir/all] Error 2
>> make: *** [all] Error 2
>> On 20-Apr-08, at 10:34 AM, William Kyngesburye wrote:
>>> I think there was a fix for this recently in trunk, and maybe it's
>>> not in the diagram branch.  The release tag works fine.  You could
>>> try grabbing cmake/FindPostgres.cmake from trunk to replace what
>>> you have in the diagram branch.
>>> On Apr 20, 2008, at 11:03 AM, John Abraham wrote:
>>>> I'm trying to build the "diagram" branch on MacOSX Leopard.  I
>>>> followed the instructions in the docs, and did get it compiled
>>>> and running.  I'm pretty proud of myself since I haven't
>>>> programmed in C for a decade or so (java programmer now.)
>>>> Except there is one problem.  The Postgres stuff wasn't found by
>>>> cmake, so there was no Postgis support in my build.
>>>> So I tried to set up cmake to find my postgres.  I found the file
>>>> FindPostgres.cmake and found that it uses environment variables,
>>>> so tried to set those using -D options to cmake.  Now it won't
>>>> compile at all, with the following error.  I do have a libpq-fe.h
>>>> in /usr/local/pgsql/include.  I didn't make Postgres from source,
>>>> just installed it.
>>>> Thanks for any help,
>>>> John Abraham
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> Earth: "Mostly harmless"
>>> - revised entry in the HitchHiker's Guide to the Galaxy
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> "We are at war with them. Neither in hatred nor revenge and with no
> particular pleasure I shall kill every ___ I can until the war is
> over. That is my duty."
> "Don't you even hate 'em?"
> "What good would it do if I did? If all the many millions of people
> of the allied nations devoted an entire year exclusively to hating
> the ____ it wouldn't kill one ___ nor shorten the war one day."
> <Ha, ha> "And it might give 'em all stomach ulcers."
> - Tarzan, on war
