[Qgis-user] Postgres dependency on mac build
William Kyngesburye woklist at kyngchaos.com
Sun Apr 20 12:12:52 PDT 2008
Qgis won't be 64bit on OSX until Qt is 64bit.  Currently Qt depends on
Carbon (which is 32bit-only), but there is work to shift away from
Carbon in Qt 4.4.
On Apr 20, 2008, at 1:59 PM, John Abraham wrote:
> Looks like that might have done it, thanks.  -D POSTGRES_CONFIG=/usr/
> local/pgsql/bin/pg_config to cmake.
> I'm off an running.  Looks like it's not 64bit.  Is it
> multithreaded?  I have a new Mac Pro.
> John
> On 20-Apr-08, at 12:21 PM, William Kyngesburye wrote:
>> Puzzling why it's not finding Postgres without any options.
>> But, the CONFIG option should point to a file (pg_config), not a
>> folder. (Same goes for library options, but not for include dir
>> options)
>> I've noticed that the "Found ..." feedback is not always correct,
>> or you just have to read more into what it says.  Like your
>> Postgres response: it says "it's a directory", which can mean "it's
>> not supposed to be a directory".
>> Also, when reconfiguring, make sure to clean first, or it may
>> remember the previous configuration.  Cleaning is not thorough in
>> cmake, so the easiest way is to build outside the source.  ie:
>> in the qgis source dir,
>> mkdir build-osx
>> cd build-osx
>> cmake [your options] ..
>> (note the .. instead of . for the source dir option)  Then you can
>> just trash the contents on build-osx to clean, before reconfiguring.
>> On Apr 20, 2008, at 12:58 PM, John Abraham wrote:
>>> Thanks for the hint.  I can't see a difference (svn diff) between
>>> the two cmake directories.
>>> I tried deleting my build directory, and redoing the cmake command
>>> with -D POSTGRES_CONFIG=/usr/local/pgsql/  and it responded
>>> -- Found PostgreSQL: sh: /usr/local/pgsql: is a directory/
>>> libpq.dylib
>>> but then I got the same error (below) when I ran make :(
>>> John
>>> [ 43%] Building CXX object src/app/CMakeFiles/qgis.dir/qgisapp.o
>>> In file included from /Users/jabraham/Development/qgis/src/src/app/
>>> qgisapp.cpp:168:
>>> /Users/jabraham/Development/qgis/src/src/app/qgsdbsourceselect.h:
>>> 27:22: error: libpq-fe.h: No such file or directory
>>> 112: error: ‘PGconn’ has not been declared
>>> 118: error: ‘PGconn’ has not been declared
>>> 141: error: ISO C++ forbids declaration of ‘PGconn’ with no type
>>> 141: error: expected ‘;’ before ‘*’ token
>>> make[2]: *** [src/app/CMakeFiles/qgis.dir/qgisapp.o] Error 1
>>> make[1]: *** [src/app/CMakeFiles/qgis.dir/all] Error 2
>>> make: *** [all] Error 2
>>> On 20-Apr-08, at 10:34 AM, William Kyngesburye wrote:
>>>> I think there was a fix for this recently in trunk, and maybe
>>>> it's not in the diagram branch.  The release tag works fine.  You
>>>> could try grabbing cmake/FindPostgres.cmake from trunk to replace
>>>> what you have in the diagram branch.
>>>> On Apr 20, 2008, at 11:03 AM, John Abraham wrote:
>>>>> I'm trying to build the "diagram" branch on MacOSX Leopard.  I
>>>>> followed the instructions in the docs, and did get it compiled
>>>>> and running.  I'm pretty proud of myself since I haven't
>>>>> programmed in C for a decade or so (java programmer now.)
>>>>> Except there is one problem.  The Postgres stuff wasn't found by
>>>>> cmake, so there was no Postgis support in my build.
>>>>> So I tried to set up cmake to find my postgres.  I found the
>>>>> file FindPostgres.cmake and found that it uses environment
>>>>> variables, so tried to set those using -D options to cmake.  Now
>>>>> it won't compile at all, with the following error.  I do have a
>>>>> libpq-fe.h in /usr/local/pgsql/include.  I didn't make Postgres
>>>>> from source, just installed it.
>>>>> Thanks for any help,
>>>>> John Abraham
>>>>> jabraham at ucalgary.ca
>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>> http://www.kyngchaos.com/
>>>> Earth: "Mostly harmless"
>>>> - revised entry in the HitchHiker's Guide to the Galaxy
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> "We are at war with them. Neither in hatred nor revenge and with no
>> particular pleasure I shall kill every ___ I can until the war is
>> over. That is my duty."
>> "Don't you even hate 'em?"
>> "What good would it do if I did? If all the many millions of people
>> of the allied nations devoted an entire year exclusively to hating
>> the ____ it wouldn't kill one ___ nor shorten the war one day."
>> <Ha, ha> "And it might give 'em all stomach ulcers."
>> - Tarzan, on war
"This is a question about the past, is it? ... How can I tell that the
past isn't a fiction designed to account for the discrepancy between
my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
