[Qgis-user] installing on Ubuntu
Jürgen E. Fischer jef at norbit.de
Thu Apr 24 09:07:54 PDT 2008
Hi Carlos,
On Thu, 24. Apr 2008 at 17:13:50 +0200, Carlos Dávila wrote:
> I don't know if it's related, but I can't run qgis installed from source
> (r8377). Installation seems to finish correctly, but when I try to run
> the application, always get this error:
> /usr/local/qgis/bin/qgis: error while loading shared libraries:
> libqgis_core.so.0.10: cannot open shared object file: No such file or
> directory
Either add /usr/local/qgis/lib to your $LD_LIBRARY_PATH or add
/usr/local/qgis/lib to /etc/ld.so.conf (or create a
/etc/ld.so.conf.d/qgis.conf containing that path) and run ldconfig.
BTW if I understood correctly Chris downloaded and installed the debs
from launchpad manually instead of using apt-get - including an old
version of libqgis1.  Using apt-get that shouldn't happen.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
