[Qgis-user] GPS Plugin - QGIS 0.11- Mac OSX.5.4
Alex Mandel tech_dev at wildintellect.com
Wed Aug 13 02:45:30 PDT 2008
Mars Sjoden wrote:
> Hello Q list,
> I am having difficulty getting the GPS Plugin working for downloading
> from my Garmin GPSmap 60CSx
> I have gpsbabel version 1.3.4 installed and active on my PATH.
> (long story but the new v1.3.5 does not work on my iMac)
> I am able to use gpsbabel just fine from the command line. ie. downloads
> and uploads fine from/to my gps.
> I am pretty sure this is not a gpsbabel issue as far as I can tell.
> So I launch the GPS Plugin "GPS Tools"
> Select "Download from GPS" tab.
> Select *Garmin * from the GPS device button list.
> Port (There are no choices here from the button list)
> Feature type: *Waypoints*
> I tried the original setup and receive this output:
> *The layer is not a valid layer and can not*
> *be added to the map*
> I decided to add a gpx layer to QGIS, and name it as the layer for
> output.  Same output.
> I then edited the device to look like, for example waypoint download:
> gpsbabel -w -i garmin -f usb: -o gpx %out
> I still receive the same output as above.
> I am wondering what I am doing wrong here,
> how can I get this working?
> I can remember using the gps plugin in 0.8 and it working slick with out
> any need for fiddling.
> thank you!
> mars
Here is my usb line (Linux with Garmin 60csx)
%babel -i garmin -f usb: -o gpx -F %out
I'm to tired to reason out the difference but give it a shot.
Alex
