[Qgis-user] GPS Plugin - QGIS 0.11- Mac OSX.5.4
John C. Tull
john.tull at wildnevada.org
Wed Aug 13 10:16:35 PDT 2008
Mars,
Device discovery has never worked on OS X in qgis, to my knowledge. My
waypoint download line looks like this, but I use a usb to serial
adapter:
%babel -w -i garmin -o gpx -f /dev/cu.usbserial-ftCASM51 -F %out
You need to find the full device id either by looking at items listed
under /dev in the Terminal, or by using something like gpsbabel+ to
help you id the proper device string. You can set up a transfer and
see the full command in the log window after you run it in gpsbabel+.
Hope that helps,
John
On Aug 12, 2008, at 10:16 PM, Mars Sjoden wrote:
> Hello Q list,
> I am having difficulty getting the GPS Plugin working for
> downloading from my Garmin GPSmap 60CSx
> I have gpsbabel version 1.3.4 installed and active on my PATH.
> (long story but the new v1.3.5 does not work on my iMac)
> I am able to use gpsbabel just fine from the command line. ie.
> downloads and uploads fine from/to my gps.
> I am pretty sure this is not a gpsbabel issue as far as I can tell.
> So I launch the GPS Plugin "GPS Tools"
> Select "Download from GPS" tab.
> Select Garmin from the GPS device button list.
> Port (There are no choices here from the button list)
> Feature type: Waypoints
> I tried the original setup and receive this output:
> The layer is not a valid layer and can not
> be added to the map
> I decided to add a gpx layer to QGIS, and name it as the layer for
> output. Same output.
> I then edited the device to look like, for example waypoint download:
> gpsbabel -w -i garmin -f usb: -o gpx %out
> I still receive the same output as above.
> I am wondering what I am doing wrong here,
> how can I get this working?
> I can remember using the gps plugin in 0.8 and it working slick with
> out any need for fiddling.
> thank you!
> mars
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080813/0a3bcbd4/attachment.html>
