[Qgis-user] GPS Plugin - QGIS 0.11- Mac OSX.5.4
Mars Sjoden
amagine at telus.net
Wed Aug 13 11:01:01 PDT 2008
Thanks John,
On 13-Aug-08, at 10:16 AM, John C. Tull wrote:
> Mars,
> Device discovery has never worked on OS X in qgis, to my knowledge.
> My waypoint download line looks like this, but I use a usb to serial
> adapter:
> %babel -w -i garmin -o gpx -f /dev/cu.usbserial-ftCASM51 -F %out
> You need to find the full device id either by looking at items
> listed under /dev in the Terminal, or by using something like
> gpsbabel+ to help you id the proper device string. You can set up a
> transfer and see the full command in the log window after you run it
> in gpsbabel+.
This is essentially what I did, ran a wpt download and placed
command into the WPT field of QGIS gps plugin device editor.
I do not understand since I thought QGIS just passed the command to
gpsbabel and placed the gpx file as a layer.
Using gpsbabel from command line works fine.
> Hope that helps,
> John
> On Aug 12, 2008, at 10:16 PM, Mars Sjoden wrote:
>> Hello Q list,
>> I am having difficulty getting the GPS Plugin working for
>> downloading from my Garmin GPSmap 60CSx
>> I have gpsbabel version 1.3.4 installed and active on my PATH.
>> (long story but the new v1.3.5 does not work on my iMac)
>> I am able to use gpsbabel just fine from the command line. ie.
>> downloads and uploads fine from/to my gps.
>> I am pretty sure this is not a gpsbabel issue as far as I can tell.
>> So I launch the GPS Plugin "GPS Tools"
>> Select "Download from GPS" tab.
>> Select Garmin from the GPS device button list.
>> Port (There are no choices here from the button list)
>> Feature type: Waypoints
>> I tried the original setup and receive this output:
>> The layer is not a valid layer and can not
>> be added to the map
>> I decided to add a gpx layer to QGIS, and name it as the layer for
>> output. Same output.
>> I then edited the device to look like, for example waypoint download:
>> gpsbabel -w -i garmin -f usb: -o gpx %out
>> I still receive the same output as above.
>> I am wondering what I am doing wrong here,
>> how can I get this working?
>> I can remember using the gps plugin in 0.8 and it working slick
>> with out any need for fiddling.
>> thank you!
>> mars
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20080813/d46e162d/attachment.html>
