[Qgis-user] Postgis, Qgis, uDig?
Dane Springmeyer
blake at hailmail.net
Thu Aug 14 20:02:44 PDT 2008
I like both QGIS and uDig.
I am constantly needing a quick map view of postgis spatial tables and
I tend to use Qgis much more often for one primary reason: it loads
faster with a nice blank map and the number of buttons to press to get
your postgres data up on the map canvas from scratch are fewer than
udig.
However, I think uDig excels at working with postgis data in several
ways:
1) uDig does not depend upon a field named oid or a specific unique id
field with a constraint. I'm not sure what shortcut uDig uses here but
if you are just trying to view your postgis data, getting it to load
up in Qgis due to this restriction can be troublesome at first.
2) uDig has a nice 'Catalog' window that allows you to easily refresh
and reload you connection to postgres tables without having to step
through multiple pop-up windows. In fact you can drag and drop postgis
layers into your map view.
Cheers,
Dane
On Aug 14, 2008, at 4:10 PM, John C. Tull wrote:
> Personally, uDig was not a satisfying experience when I used it.
> Maciej did a good job listing the shortcomings of qgis and postgis.
> I quite enjoy qgis as a front-end to postgis, but you may want to
> give both a try to find out for yourself.
> John
> On Aug 14, 2008, at 1:33 AM, Agustin Lobo wrote:
>> Hi!
>> Do I need (or is it convenient) uDig to use PostGis or
>> QGIS is enough (or even better) as a front end for PostGis?
>> Thanks
>> Agus
>> Dr. Agustin Lobo
>> Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
>> LLuis Sole Sabaris s/n
>> 08028 Barcelona
>> Spain
>> Tel. 34 934095410
>> Fax. 34 934110012
>> email: Agustin.Lobo at ija.csic.es
>> http://www.ija.csic.es/gt/obster
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
