[Qgis-user] QGIS Metis crashes using SPIT
Gabriele Monfardini
gabrimonfa at gmail.com
Thu Aug 21 01:25:02 PDT 2008
I'm using qgis metis on Ubuntu Hardy, compiled from SVN stable branch
with Python support, without any problem.
The binary was compiled against Qt 4.4.0 and is running against Qt 4.4.0.
All appears to work correctly apart from importing a shapefile into a
Postgis layer with SPIT that crashes qgis.
The db is up and running fine.
The same happened also with unstable branch, compiled 1 week ago, all
works correctly, but SPIT makes qgis to segfault.
Is there any open issue against SPIT plugin or qgis?
It would be useful if I post the stack trace?
Btw, congratulation to all the developers, qgis is getting better and
better every new release!
Gabriele
