[Qgis-user] assigning RGB values in QGIS 0.11
maning sambale emmanuel.sambale at gmail.com
Fri Aug 22 04:05:50 PDT 2008
Found it in the RGB sliders.  You can get html notation in the Color
Palettes > Web Safe Colors
On 8/22/08, Alex Mandel <tech_dev at wildintellect.com> wrote:
> maning sambale wrote:
>> Forgive me for asking, I can't seem to find the "old" way of assigning
>> RGB values in the Layer Properties fill color window.  Is it
>> depracated in "Metis"?  I find it easier to use RGB values than the
>> HTML notation, as I can use the same values for ps.map of GRASS.
>> cheers,
>> maning
> Are you talking about vector or raster layers? When I opened a vector
> layer properties on the symbology tab, if I click on the color swatch I
> get swatches, a palette HSV and RGB fields. I don't see any HTML notation?
> I'm using Ubuntu 8.04 launchpad repos.
> Alex
> Qgis-user mailing list
| __.-._  |"Ohhh. Great warrior. Wars not make one great." -Yoda     |
| '-._"7' |"Freedom is still the most radical idea of all" -N.Branden|
|  /'.-c  |Linux registered user #402901, http://counter.li.org/     |
|  |  /T  |http://esambale.wikispaces.com|
| _)_/LI
