[Qgis-user] add a gml layer
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Fri Jun 20 09:14:54 PDT 2008
On Fri, 2008-06-20 at 09:11 -0700, Tara Athan wrote:
> I am attempting to add a gml layer to the QGIS dataset that will be used
> in the next release of the QGIS manual (v 1.0).
> I took the lakes.shp shapefile from the existing dataset and used ArcMap
> to convert to gml (sorry, I couldn't figure out any other way.)
> The resulting layer loads into ArcMap OK, although it complains about
> the spatial reference, but when I try to load it into QGIS
> (Click Layer -> Add Vector Layer, then select the file and the type
> [OGR] Geography Markup Language (*.gml) )
> I get the error
> ... is not a valid or recognized data source
> The file is available here:
> http://www.alt2is.com/joomla/index.php?option=com_docman&task=doc_download&gid=4&Itemid=42
> I don't know if the problem is with the file, the software or the
> procedure. If anyone has or knows how to create GML files that work with
> QGIS, I am willing to use that, as long as it is in Alaska, as that is
> the region of our dataset.
> Thanks, Tara
Tara,
I think ogr2ogr supports GML files. Why not trying to convert with it?
ogr2ogr --formats | grep GML
-> "GML" (read/write)
