[Qgis-user] Select Features bug
Lionel Roubeyrie lroubeyrie at limair.asso.fr
Mon Oct 6 02:41:04 PDT 2008
Ok, 1.0.0 solves the problem, I can now select multiple polygons without
the entire dataset.
Thanks
Otto Dassau a écrit :
> Hi Lionel,
> On Mon, 06 Oct 2008 10:49:14 +0200
> Lionel Roubeyrie <lroubeyrie at limair.asso.fr> wrote:
>> Hi Otto,
>> I want to select polygons on the canvas and see/extract their datas in
>> the attribute table, but like I said, at a moment, all features are
>> selected although I clicked (drawned a rectangle) in a unique feature.
>> I going to try the 1.0.0 version...
> ok, then I understood correctly, I think. This is working for me with a 1.0.0
> preview and I am using a debian lenny OS. If it still doesn't work for you with
> QGIS version 1.0.0 but on a different OS, please write again to the list, and
> ask if people using your OS can verify.
> thanks a lot
>   Otto
>>> Hi Lionel,
>>> I tested with the current 1.0.0 preview and can't reproduce this behavior.
>>> Holding down the "Ctrl" key I can select as many features as I like. But
> there
>>> is a little difference:
>>> If you open the attribute table after you useed the "Select Features"
>>> tool, you only see the selected features, of course, not all existing.
>>> You can change this behavior, if you open the attribute table first and then
>>> start to selected features. In that case, all feature are displayed in the
> table
>>> but only those you selected are color-coded.
>>> regards,
>>>  Otto
>>> On Mon, 06 Oct 2008 10:08:44 +0200
>>>> Hi all,
>>>> when using the "Select Features" tool on a polygon shapefile and holding
>>>> down the "Ctrl" key for selecting some features by hand, we can select
>>>> 6-7 polygons, but after the entire dataset is selected! Is there an
>>>> alternate solution? Thanks
Lionel Roubeyrie - lroubeyrie at limair.asso.fr
Chargé d'études et de maintenance
LIMAIR - la Surveillance de l'Air en Limousin
http://www.limair.asso.fr
