[Qgis-user] move vertex to specified coordinates?
Magnus Homann
magnus at homann.se
Wed Oct 22 10:02:02 PDT 2008
matt wilkie skrev:
> Hi Brent,
> I created the desired coordinates in a .csv file, loaded as delimited text,
> set the snapping preference to a generous distance and attempted to move
> vertexes of a polygon layer to coincide with the points. No go. "Snapping"
> in qgis does not seem to mean the same thing as in all other software I've
> used to date.
Have you checked the snapping optiions i Project properties -> Snapping
options... ? I believe you must check the layers you enable snapping on,
and set the tolerance to a value >0.
